Leak Stereo 30 Plus and Stereo 70
Old 18th May 2018, 08:51 AM   #1
Brucev is offline Brucev
Default Leak Stereo 30 Plus and Stereo 70
Help required please.
I have a Leak Stereo 30 plus and the headphone output has lost the left hand channel. On investigation I found that R56 L resistor had gone open circuit. The end cap had departed from the resistor body!
Looking at the circuit R56L and R56R are 100 ohms but there is no indication as the the wattage rating. They are quite large.
Can anyone help me with identifying a suitable replacement resistor please.
Old 18th May 2018, 09:12 AM   #2
Mooly's Avatar
Hmmm. Worst case which assumes the amp is being driven with a sine test signal at full power would need something around 6 watts rating. That is worst case and assumes the headphones are pretty much zero impedance.
For normal music at any reasonable volume and a 2watt carbon or metal film would be fine and would not even get warm.
There is a huge difference between full power testing and normal usage. The amp itself wouldn't survive that long under full power test conditions so you have to be realistic sometimes.
Old 18th May 2018, 09:24 PM   #3
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by Mooly View Post
Hmmm. Worst case .... a 2watt carbon or metal film would be fine ....
And remember this is a headphone output. If we were melting 6 Watt resistors the headphones would burn your ears.
So the end-cap fell off because the crimp got old, not because it was abused with audio.
Agree 2W ought to be affordable over-kill; unless the thing must pass sustained full-power tone-tests with a short in the HP jack, then use 5W.
Old 18th May 2018, 10:03 PM   #4
motronix is offline motronix  Israel
The original Cream-colored resistors are 3W 100R 5%
Old 19th May 2018, 07:35 AM   #5
These are a dark brown coloured resistor and are approx twice the physical size of R1, R2 and R3 which are 3 watt cream coloured resistors.
Leak Stereo 30 Plus and Stereo 70Hide this!Advertise here!
Leak Stereo 70 Carlosraj Solid State 10 27th March 2018 03:28 PM
Leak stereo 70 Mikeashb Solid State 6 14th March 2015 05:44 PM
HELP needed - LEAK Varislope 2 Stereo + Stereo 20 with pictures... triole1 Tubes / Valves 13 28th March 2014 06:55 AM
leak stereo 60 2SA991 Tubes / Valves 1 7th January 2014 10:47 PM
Leak Stereo 30+, Stereo 70 & Delta 70 (UK sale) Tweedle12 Swap Meet 2 13th April 2012 11:32 PM
