Greetings, long time lurker, first time poster
So let's get straight to the chase. im looking to build a new amplifier and im looking for home design help
DESIGN GOALS
Class AB
200W into 8 Ohm
mono board
Things im looking for help with.
What should i use, BJT's or MOSFET? i like the idea of MOSFET, but ive never heard a MOSFET class AB amplifier before. so if someone can chip in on that.
im not an expert so ive been looking at ready made designs. what im looking at right now is the Honey Badger or the massively discuessed Apex HV250, or maybe another design i havent found it myself yet.
Since i couldn't find a gerber file or PCB for the HV250, i copied it to make my own PCB if i go that route, i also added a small circuit for a clipping light, because why not. Sechmatic Ignore the PCB design thats there, probably going to scrap it and start over
What im also looking for help for is a PREAMP. this is where im really lost, but i would rather get the amp done before this. what i would like is (because everyone can dream right?) class A pre. BJT, JFET or MOSFET? maybe a Nelson Pass design, but haven't looked to far into that yet
Not related to this, but plan on it later on, POWER METERS. since the LM3915 is almost impossible to find now, may try to make a circuit with discretes or some other analog IC
If anyone needs more info let me know, i might have accidentally left some info out thats needed.
DESIGN GOALS
Class AB
200W into 8 Ohm
mono board
Check out some of the designs from Apex Audio, the range from 50 to +1000 watts all good HQ designs from what I have seen, He has them posted in is FB pages as well.
Great Stuff !!
http://www.diyaudio.com/forums/search.php?searchid=18417628
jer
P.S. Sorry, Somehow I missed the part were you had already mentioned Apex in your post..... Cheers !!
Great Stuff !!
jer
