Zenquito
gaetan8888 said:
Surfing on the diyaudio forum, I found your thread.
Here's an modified version of the Buzquito;
http://oamlabs.home.sapo.pt/oamlabs_a500d.html
Gaetan
djk said:
Nice 50W amp.
R17, C15 would do more good on the other side of the relay.
Leolabs said:
Wonder do u guys have the offset drifting problem???
pantefeve original Buzquito (think it is)
is told to be biased 400mA and uses a paralleled pair of BUZ900/905 N+P
This means 200mA per BUX9xx transistor.
This buzquito is specified 150 Watt Class AB into a pair of LSP with 88dB SPL.
Offset drift when using more current = Class A should be less of a problem
than an amplifier 'running cold' ( class B, class AB low bias).
Of course also good temp compensation of input 2SK170/2SJ74
will effect eventual drift of offset.
Preferably they should be out together in close contact.
Yes, even the temperature of 2 VAS transistors in this diagram can effect offset!
In this following diagram, at plantefeve :cool: great website :cool:
Website:
http://perso.orange.fr/jm.plantefeve/sche.html
Regards :) Lineup
Hello lineup
What are the use of the two 220 ohm potentiometers ?
Any good replacements for the BUZ900/905 output transistors that can be found in north america ?
Anybody did made that Buzquito amp, how it sound ? and anybody compared it to Aska amp or any other excellent diy amp ?
Thank
Gaetan
Regards :) Lineup
Hello ;) ,
Yes :cool: http://perso.orange.fr/pol.bct/JFG/Dsc02013.jpg
the thermal coupling improves the stability of the offset largely. To perfect that, drivers 2N3440/2N5416 would have to be also coupled, but it is difficult to find a radiator adapted to that (electric insulation), it would also preferably be necessary to modify the PCB.
example of radiator: to see datsheet 2SA607 http://pdf1.alldatasheet.com/datasheet-pdf/view/107665/ETC/2SA607.html
@ + Jean-François ;)
gaetan8888 said:
Hello
Gaetan
Hello ;),
Pair 2SK170/2SJ74 is however better and however easier to pair, however that depends indeed on the recus batches... personellement, in spite of a number much more significant of 2SK246/2SJ103 (50 pairs) I had much more evil to make good pairs with those Ci. The BC550/BC560 save small a 0,1db. Work on the decoupling of the zéners of 10V is well seen, that gets along and strongly the noise decreases by it. Personally, 0,1µF MKT + 10µF Tantale solid Alusol Philips, the zéner of 10V consists of two zéners of 5,6V + 4,7V, which offers the advantage of making a zéner compensated in temperature. Thermal coefficient opposed below and to the top of 5V.
http://perso.wanadoo.fr/pol.bct/JFG/Dsc02013.jpg
http://perso.wanadoo.fr/pol.bct/JFG/Dsc02015.jpg
http://haute.fidelite.com.online.fr/coin-integriste/Jean-Francois-Gros/mosquito-JFgros.html
hi
Think Leolabs is very correct.
Advice is this: Use the original 2SK1058 / 2SJ162, for Zenquito standard circuit!
They should not be too difficult to find and buy
in any part of world where you may live.
JFG67 said:
Hello ;),
Pair 2SK170/2SJ74 is however better and somewhat easier to match,
but this can depend very much indeed, if buying them all from one same batch/package... or not.
Personally, even if having larger number of 2SK246/2SJ103 (50 pairs),
I had much more difficult to find good matching pairs with those.
The cascoding transistors, BC550/BC560 save small a 0,1db.
Work on the decoupling of the 10V zeners is recommended,
in that you can get a good noise reduction, decrease by doing so.
Personally, I use 100nF MKT + 10µF solid Tantale, Alusol Philips.
Each zener of 10V consists of two zeners of 5,6V + 4,7V,
which offers the advantage of making the zener having good compensation for temperature.
( makes combination almost zero temp drift coefficient )
Thanks J-F.
Very good information, indeed,
for building BUZquito or ZENquito.
:) lineup
lineup said:
hi
Thanks J-F.
:) lineup
Hello ;),
Mosquito, in use 2SK170/2SJ74 + BC550c/BC560c + 2N3440/2N5416 + 3x 2SK1058/2SJ162
Simulations : (Francis Brooke) http://monsite.wanadoo.fr/francis.audio
Linearite, Distorsion H2/H1=-61.8dB et H3/H1=-76.0dB pour Us=4V a 1kHz sur R=5.5ohm Zenquito Evolution
Linearite, Distorsion H2/H1=-83.0dB, H3/H1=-93.3dB et H4/H1=-115.4dB pour Us=4V a 1kHz sur R=5.5ohm Zenquito Evolution
H2/H1=-84dB H3/H1=-94dB H4/H1=-128dB Mosquito schéma de base JMP http://perso.orange.fr/jm.plantefeve/sche.html
H2/H1=-93dB H3/H1=-102dB H4/H1=-140dB Mosquito JFG67 classe A 25WA/80WB/8ohms Alim +-42V 8x47000µF/Pi R=0,47ohm/11W
The very first original diagram of Mosquito is at the foot of the page.
R Pro2 = 2W
Modifications :
+-50V = +-42V
R 82 ohms in drivers = 120ohms because I drivers = 10/12 mA for I = 1,25A in 3x 2SK1058/2SJ162 for 25W classe A
Zéner 10V = zéner 5,6V+4,7V + 0,1µF MKT + 10µF Tantale Alusol
100µF = 220µF 105° C136 Philips + 1000µF FRS 105° Roedertein
@ + JF ;)
lineup said:
hi
:) lineup
Hello ;)
Extreme Attention for :mad: BBM audio & electronics :mad: :
the 2SK1058 are not 2SK1058 drain and source is reversed
http://forums.delphiforums.com/n/mb/message.asp?webtag=haute_fidelite&msg=21770.1
vvvvvvvvvvvvv
De: Philby11 22-févr 11:22
À: Plantefève Jean-Marc (PJeanMarc) non-lu 11 de 12
21770.11 en réponse à 21770.10
Bonjour Jean François et Jean Marc,
On a eu aussi des soucis avec des mosfets 1058 Selectronic sur HC FR,
mais ils ont été très corrects, et ont changé tous les transistors
de ce lot.
http://www.homecinema-fr.com/forum/viewtopic.php?p=169818391#169818391
Ces mosfets sont inversés en Drain et source (ce ne sont pas des
1058!!!) et la diode en inverse drain source fait des dégats...
Et il y en a encore dans la nature, attention!!! :
http://cgi.ebay.fr/ws/eBayISAPI.dll...Sell_LogicX&refwidgettype=cross_promot_widget
Philippe
AAAAAAAA
@ + JF ;)
