single so8 to dual dip opamp adapter available from BrownDog
Old 30th May 2002, 06:30 AM   #11
puppyslugg is offline puppyslugg
The BrownDog adaptors are terrific! Works as advertised.
Recently swapped out the 5532's in my CD player with AD8610's/adaptors. The adaptors made the job a breeze!
Thanks, morsel.
Old 30th May 2002, 07:59 AM   #12
morsel is offline morsel
morsel's Avatar
My pleasure.
Old 30th May 2002, 08:25 AM   #13
fmak is offline fmak
Thanks, morsel.
The AD 8610s are even better if you current load them.
On a separate point, does anyone know if there are coupling problems between channels if one current loads dual opamps ?
Old 30th May 2002, 08:49 AM   #14
[QUOTE]Originally posted by fmak
[B]
"The AD 8610s are even better if you current load them."
Agreed.
Just waiting for morsel's cascode current source opamp adaptor.
Old 30th May 2002, 03:30 PM   #15
PhopsonNY is offline PhopsonNY  United States
PhopsonNY's Avatar
Thumbs up Cascode current source opamp adaptors!
Are these to be available through brnDog directly or do we have to order these through Morsel? What is the estimated ETA?
Morsel...any thoughts on an adaptor that will take an LDO?
Might be crazy idea, but just thought I would ask.
The BrnDog adaptors are great!!!
Old 30th May 2002, 06:17 PM   #16
sonnya is offline sonnya  Denmark
sonnya's Avatar
Hi Morsel
I think you have got you own little fanclub here!
Sonny
Old 30th May 2002, 08:30 PM   #17
morsel's Avatar
Hee hee!
I designed the BrownDog opamp adapter as a community service, but I do not make any money from them, nor do I sell them.
Get them directly from BrownDog:
http://brndog.com/SingletoDual.html
http://brndog.com/priclist.html
Order the version with pins unless you know you don't want pins. The pre-installed press fit pins are quite good and save you the trouble of installing your own pins. They are $2.39 each with a minimum order of 5, or $1.59 each without pins. Quantity discounts are available.
BrownDog has a secure page for online ordering. Orders are filled quickly and shipped all over the world via priority mail, UPS, or FedEx.
Old 30th May 2002, 08:49 PM   #18
morsel's Avatar
Phopson, about the low drop out regulator, that is rather specialized. Altering the supply voltage for the opamp would require a much bigger adapter. I know you love the AD8610. You can try lowering the power rails that supply the opamp from 15V to 12V, the rest of the player might still work fine at the lower voltage. I think that would be the easier approach.
Alternatively, you could use the AD825 or AD823 if you want better high end detail than the AD8512 you are using. Don't hold your breath over the new FastFET AD8065, it probably won't be as good as the AD8610. Still, it will be interesting to check out.
Old 1st June 2002, 07:34 PM   #19
PhopsonNY's Avatar
Wink ad8620 now available
Hey all,
the ad8620 (dual version of ad8610 is now available)
cheers
http://products.analog.com/products/...product=AD8620
single so8 to dual dip opamp adapter available from BrownDogHide this!Advertise here!
WTB: dual soic to dil adapter JonHarrison Swap Meet 3 23rd May 2007 01:24 AM
FS or Trade: AD8610AR on BrownDog adapter theAnonymous1 Swap Meet 1 1st March 2007 09:24 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 03:15 PM
Single or Dual opamp package? JojoD818 Solid State 15 19th December 2003 03:09 PM
JRC 45580 opamp..dual or single?? tone Digital Source 3 30th April 2003 06:21 AM
