Since a couple of days there seems to have appeared a problem.
When powering on, relay clicks on (after a while as usual) but speaker setup-icons are gone.
Sometimes they pop up shortly several times with a pops in speakers, just like the decoder can't decide what to do
Switching to other program doesn't help except when I switch to Pure direct.
Then icons appear, and when switching back to another program they remain there. It does not change depending on input.
When I checked there were no error codes, and other data looked OK.
The only thing was the soundcheck, putting out a 1khz tone, didn't work, but speaker icons wasn't active then either.
After testing I powered on and it worked as usual
Does anyone have a clue what's going on ?
Figge
Figge
Thank's Jon, I will check that.
Seems that printing the schematic is a good idea. It's not easy to follow when pages doesn't harmonize in the PDF, and it's not the simplest one I've seen either
Anyway, it will take a while because I'm knocked out by the flu, so there will be no somersaults in the next few days
Best regards
Figge
Best regards
Figge
