Felt this deserved its own thread.
From Dec 2017 post:
http://www.diyaudio.com/forums/the-...owtorch-preamplifier-ii-9837.html#post5277959
My 12 cents regarding power amplifiers, based on experience:
- stability even with very difficult complex loads, no problems if the load is suddenly disconnected
- high output current capability
- excellent immunity to both air-coupled EMI interferences and supply line interferences
- sophisticated wiring topology immune to grounding scheme of remaining audio chain components
- frequency compensation network that assures high loopgain (feedback factor) even at the upper end of audio band
- very low and as linear as possible output impedance
Reasonably high slew rate and full power bandwidth at least 100kHz as a rule of thumb, no need to emphasize.
It would be nice to put some general, basic parameters/numbers to these specs.
1) stability with complex loads: basic impedance description, schematic?
2) high output current:
3) air/line EMI imunity: basic circuits for input/output
4) grounding immunity :
5) high loopgain (@~20kHz), comp network:
6) low/linear output impedance: basic impedance description
Thanks and cheers,
Jeff
From Dec 2017 post:
Thanks and cheers,
Jeff
-Flat THD vs frequency in the audio band is mandatory for me.
-flat output impedance in the audio band rather than extremely low (200df is enough).
-decent slew rate (80Vus min), as advocated by JC.
I also demand unity gain stability. Current feedback amps can provide this
This is for discrete amplifiers, too. It'd be a total waste to not optimally set your compensation for the desired gain. For opamps, sure, there's a lot of cases where unity gain is needed.
