Old 11th April 2004, 05:59 PM   #1
slowhands's Avatar
Default Need Hafler Pro6000 schematic
Trying to revive this and it is unusual enough that I need the schematic for debug. If some kind soul has this one (it's not posted on their support site), I would appreciate it.
Old 13th April 2004, 10:28 PM   #2
fab is offline fab  Canada
fab's Avatar
I don't have the P6000 but the P1500 and P3000 use the same manual and schematics. Is it possible it could basically be similar?
If you think so, I have already downloaded the P1500/3000.
Old 13th April 2004, 10:57 PM   #3
slowhands's Avatar
No, not similar despite the name similarity. P1500 is closely akin to all the other Hitachi lateral MOSFET amps.
The PRO6000 uses vertical MOSFETs in an array Anthony Holton would have been proud of: 16 per channel, on a wind tunnel heatsink. That's what I meant about significantly different. The entire amp, both channels, is on one rather large PC board, roughly 16"x14". This includes a preamp with unbalanced/balanced input and bridge switching and some signal level and fault monitoring and shutdown.
Right now the current rises very rapidly as I increase the line voltage, but not fast enough to make me think it's a short. Since this is all one board, I can't isolate channels and I can't partition this easily for debug.
If I can't get a schematic, I can still use the chassis and power supply. It has forced air cooliing, an 1800 VA toroid, and 2 42,000mf 100v caps that are all fine. Do you think this would be all right for a Zen amp?
Old 15th April 2004, 02:18 AM   #4
slowhands's Avatar
Hafler Technical Support replied to my request for schematic with:
Thanks for getting in touch with us. Unfortunately, after much
searching, we are unable to find a schematic for the Pro 6000 for you. All that I have available to me is the manual. Please let us know if we can do anything else for you.
It's apparently an orphan from the early days of Hafler Rockford. Oh well, Zenquito here I come.
Old 6th July 2010, 08:26 PM   #5
Default Hafler Schematic diagram
anyone got a hafler Pro-6000 schematic diagram?
Old 15th June 2011, 01:58 PM   #6
anyone got a power amplifier Hafler model PRO-6000 schematic diagram for technical servicing?
Old 24th June 2011, 04:32 AM   #7
I build the power amplifier ALL Mosfets, with Exicon mosfets outputs.
400Watts RMS per channel - 0.02 THD 20hz-20.000hz- 8 OHMS.
response frequency- 1Hz- 300.000HZ +_ 0.1DB.
Damping factor- 20-500hz- 800
Slew rate- 100V uS
all resistor's metal film 1% Vishay
All cap. Wima MKP10 and black gate eletrolitic
Schematic for Hafler T3 preamp? fly135 Instruments and Amps 9 2nd October 2010 09:39 PM
Hafler P500, need schematic, manual, and some help still4given Solid State 25 29th December 2007 07:17 AM
anyone got a hafler 9505 schematic? lt cdr data Solid State 20 29th March 2007 04:21 PM
need a schematic for hafler pro2400 teknica Solid State 0 1st February 2006 02:42 PM
Hafler DH-225 and P-230 Bogie Solid State 0 11th February 2005 12:03 AM
Page generated in 0.09420 seconds (76.35% PHP - 23.65% MySQL) with 10 queries
