which subwoofer amp?
Old 16th March 2018, 09:21 PM   #1
prasi is offline prasi  India
prasi's Avatar
Default which subwoofer amp?
Hi all,
Thinking of building a simple sub amp with 250-300W power@4ohm and an active sub x-over. I already have the x-over and making it, but I am not able to decide on the amp.
I have in mind ESP P68 and Legend Stage Master by Dr. Bora (may god rest his soul in peace).
The sub is a dayton DVC 215-88 4ohm, in 42ltr vented cab tuned to 28 hz. The amp should be capable of handling future sub too with high power handling capacity. thats why i want to have atleast 250-300 W
Currently its driven by ESP P3A directly from LFE of receiver with xo of receiver. but want to try with my external active xo and the new amp.
regards
Prasi
P.S. there is Apex BX-22 too, just added to the list!
My revamped site https://sites.google.com/site/analogdesign1234/
Old 17th March 2018, 08:30 PM   #2
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Hi Prasi, among the other options, I recommend you to look at this one - a very solid performer (6 pairs of MT-200 devices with 2 driver stages in parallel). Maximum power rating is a bit above your requirements (up to 500W), however, performance at 250-300W is very high. It's always good to have some extra headroom, especially for a subwoofer 2 ohm impedance dips are no problem.
NS Double Power
Built and tested by jwilhelm.
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 18th March 2018, 12:31 AM   #3
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I feel like subs really can use Class D well. I have always liked the sound of IRS2092 based amps. With a +/-50v supply you can get some good power with these. And they are cheap as chips.
IRS2092S 500W Mono Channel Digital Amplifier Class D HIFI Power Amp Board Digital Amplifier Module-in Instrument Parts & Accessories from Tools on Aliexpress.com | Alibaba Group
That new amp from Valery and Jeff looks like a true monster - nice but maybe too much of a good thing for a sub playing below 100Hz only?
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 18th March 2018, 03:47 AM   #4
prasi's Avatar
Hello Valery and X,
Thank you for your suggestions.
I will have a look at both versions in more details.
I think I had a look at the double barrel PCB earlier also, yes a very nice design and with lots of raw power.
Prasi
Old 18th March 2018, 12:00 PM   #5
jwilhelm is offline jwilhelm  Canada
Did you ever get those Slewmaster amps sorted out? They would work great for your sub amp. The NS-double power as Valery suggests would also be a great candidate for you.
https://www.vzaudio.com/
Old 18th March 2018, 01:36 PM   #6
prasi's Avatar
Thanks for reminding, ...One channel isnt working. but 1 does...
So I will put the slew master in sub amp with the new xo. Thanks for reminding.
regards
Prasi
Old 18th March 2018, 11:06 PM   #7
vzaichenko's Avatar
Yes, Slewmaster is a very good one as well
http://vzaudio.com/
Old 18th March 2018, 11:14 PM   #8
I sent Prasi a couple Slewmaster Sub Amp boards that I designed with Ostripper a couple years ago. They had built in Wolverine inputs retuned for subwoofer duty.
Old 18th March 2018, 11:21 PM   #9
vzaichenko's Avatar
Ahha - that's cool
http://vzaudio.com/
which subwoofer amp?Hide this!Advertise here!
FS in Los Angeles: subwoofer, subwoofer cabinet, oscilliscope, KEF center... taloyd Swap Meet 69 1st June 2018 05:00 PM
Overview about words largest Subwoofer Drivers/Transducers (SUBWOOFER BEAST) tiefbassuebertr Subwoofers 27 9th September 2012 09:42 AM
FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver matevana Swap Meet 0 12th February 2012 02:42 PM
Subwoofer build - Morel UW1258, 12" Ultimate Subwoofer mantha3 Subwoofers 46 10th October 2011 01:11 PM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
