Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Solid State Talk all about solid state amplification. |
#11 | |
As you show as UK based you could do worse than to get the BD911/912 and BD139/140 from CPC (part of Farnell). Don't buy parts from ebay as many are fake. |
#12 |
Thanks, The capacitor fed by the bridge, is that one of the 2 large blue 4700 40V [ C8 ]? can i test that one across the bridge pins. i already cut off the bridge so i can solder in a replacement tomorrow, there is no short across any of the 4 pins . does that mean the cap is ok?
#13 |
Thanks I always get my components from a nice local shop Cricklewood Electronics.
#14 |
Hi again. with the bridge removed, the plus pin and the AC pin next to it [that leg started burning the bridge] both show a short to ground.
#15 |
The cap is probably OK but with a bulb tester there would be no problem even if it were not.
Because the amp runs on a dual or split supply (giving a plus and minus rail) there will be two reservoir caps... the big blue ones ![]() My circuit doesn't seem to show much of the power supply at all but it will be text book stuff. The short you read on the bridge shows that one of the diodes has failed. |
#16 |
Thanks, I disconnected two transformer wires from the board, the 2 which go to the ac tags of the bridge there are short circuits between the pair and between each of the two and ground. Does that mean the transformer is gone?
#17 |
No, the transformer will have a very low DC resistance between the connections on the secondary. All normal
![]() It will also have a surprisingly low resistance between live and neutral as well. Again normal. |
#18 |
I got a bridge KBL08 for 75 p. Now the amp seems to work fine. Thanks so much for your patience.
#19 |
#20 |
And don't forget to check the bias setting on the channel with replacement semiconductors fitted... follow the manual for procedure.
Thread | Thread Starter | Forum | Replies | Last Post |
NP-5ex repair | Swampwalker | Feastrex | 1 | 21st October 2017 02:47 PM |
jvc ax-411 repair help | rediceman | Solid State | 3 | 5th October 2016 08:19 AM |
UPS repair | soundalot | Everything Else | 4 | 21st October 2011 01:55 PM |
DHD should repair? | Solosound | Car Audio | 5 | 9th November 2008 07:39 PM |
CDM 9/44 to repair CDM 9 Pro | Duson | Digital Source | 1 | 12th October 2005 04:41 PM |
New To Site? | Need Help? |
