Speaker Protection Using Optoisolator
Old 15th June 2018, 06:30 PM   #91
jwilhelm is offline jwilhelm  Canada
We experiment with tube hybrid design amplifiers so DC can creep up on the output (tube heater failure) or instantly skyrocket. Our present DC detection design triggers below 8Hz at 1.6 - 1.8VDC and is very reliable, but it requires rail voltage from the amplifiers main power supply. I began looking at opto-isolator design detection to eliminate the need for rail voltages.
https://www.vzaudio.com/
Old 17th June 2018, 01:31 AM   #92
synonymous is offline synonymous  United States
Send a message via MSN to synonymous
Once upon a time I was looking at a project that used a PIC controller to sense the line signal to activate power to an amp. I didn't get past entertaining ideas about it, however, It did look interesting in that PIC controllers have an analog input that one can measure voltages at. I thought about both using it as it was and also potentially using it to compare voltages. I figured that the end all to monitoring an output would be to compare it to an input. Say that the output is deviated from the input signal wave, then activate a protection circuit. This way, there would be nearly no delay at all in any protection. I don't have the programming know how or knowledge of how to create those windows of comparison, but I would imagine if you have the curiosity, you could have the end all solution.
S
Old 17th June 2018, 01:55 AM   #93
The issue I see with a protection scheme like that is you would be connecting your analog ground and digital grounds together. If this is in a two channel amplifier, you would inadvertently be tying both channels analog grounds together through the digital ground, setting you up for a ground loop issue. In our present protection schemes we use an Arduino based microcontroller but every connection to the actual amplifier is done through an optoisolator making it very simple to install in any amplifier without worry of extra noise due to grounding.
Programming for Arduino based controllers is much easier than PIC. It's all open source and there are loads of examples to control just about anything on the internet. PIC software seems to always be kept a secret with little free support.
File Type: pdf DipTrace Schematic - DC Detection 4.3 .pdf (35.3 KB, 25 views)
Speaker Protection Using OptoisolatorHide this!Advertise here!
Sharp PC900 Optoisolator argonrepublic Parts 3 31st December 2013 09:31 AM
Optoisolator compressor ideas flysig Tubes / Valves 5 30th April 2009 12:27 AM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
optoisolator VAS bias for Comp Diff? jcx Solid State 8 13th May 2005 02:43 PM
