Build STK8050 equivalent
Old 23rd February 2018, 03:17 PM   #21
SVI2004A is offline SVI2004A  New Zealand
SVI2004A's Avatar
I ran with the resistor chain current stabiliser... I wasn’t keen on the existing current stabiliser... in fact that may well be the cause of failure.... similar array wreaked havoc on V4X amps
I remember when amps were amps & speakers were nervous!
Old 23rd February 2018, 03:19 PM   #22
SVI2004A's Avatar
Those who wonder.... same power ic in Z600 Z610 Z650 V66 X90 - never see those have current stabiliser dramas they present danger to the power ic
Old 23rd February 2018, 03:29 PM   #23
SVI2004A's Avatar
This from X90... lower resistance... more class A region... ran hotter
Z600 ran 2x 3.9K a lil more relaxed on bias... you could simply hook straight up to existing current stabiliser... Id consider that reckless....
File Type: png F6B4CDFF-8754-49E0-BD99-259129782D77.png (671.1 KB, 178 views)
Old 23rd February 2018, 03:35 PM   #24
SVI2004A's Avatar
Are dang...
X90 here~
Lower resistance... runs hotter
See schematic
File Type: png 4D94D254-D1BE-4331-BEA6-06325358E4F5.png (585.2 KB, 166 views)
Old 23rd February 2018, 03:35 PM   #25
Depaj is offline Depaj  France
Ok I see what you're doing (don't totally got it but just enough to understand the concept).
I think if I do this for my friend it will have to be on a budget so I'll probably bypass the whole pcb idea and connect the components directly between pins/wires.
Old 23rd February 2018, 06:45 PM   #26
anatech is offline anatech  Canada
anatech's Avatar
Yipes! You'll live to regret that decision I think.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 23rd February 2018, 06:47 PM   #27
If it were mine I would do it for sure, and I count on insisting he decides that too but from there it's out of my hands.
Old 23rd February 2018, 06:48 PM   #28
anatech's Avatar
Speaking from experience here. I would pull out of the project. Otherwise everything that goes wrong will be your fault.
-Chris
Old 23rd February 2018, 06:52 PM   #29
I'm having cold sweats from the beginning but he really wants to see them live again. Would you recommand getting rid of the whole amplifier part, take the output of the preamp/tone control, put in a new amplifier kit using +/-48V rails and connect the output to the protection circuit. Or even get a kit with a built in protection relay and connect directly to the speakers and power meters ? It would seem that budget wise that might not even turn out to be more expensive.
Old 23rd February 2018, 06:55 PM   #30
anatech's Avatar
I would do what you are most comfortable with. If he doesn't want to do something the proper way, then bail on the project. Since you will be held responsible for what you do, recommended or not, you have every right to expect that you are allowed to do things in a reliable way. Otherwise ... you just can't win.
-Chris
Build STK8050 equivalentHide this!Advertise here!
phx7nq60e equivalent samoloko Power Supplies 1 23rd January 2015 08:51 PM
Seeking STK8050 (Technics SU-V4) Duo Solid State 9 8th April 2012 01:58 PM
Would Like to build equivalent speakers to Lenehan ML1's (Noob) bennylb0 Multi-Way 1 21st July 2010 07:52 AM
6P1 Equivalent rabidlistener Tubes / Valves 1 18th February 2008 06:48 AM
bjt equivalent distortion Parts 1 7th March 2004 12:16 PM
