HELP HELP HELP - Just blew my amp, can't afford a new one.
Old 9th February 2018, 07:05 PM   #31
SVI2004A is offline SVI2004A  New Zealand
SVI2004A's Avatar
The cpu May signal check amp output in some self test, and with shorted outputs or no outputs it may be not be getting some signal in a test.
More computer power in these things than a old pc...
I remember when amps were amps & speakers were nervous!
Old 9th February 2018, 07:10 PM   #32
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
This amplifier is uProcessor controlled and if the output lines of each amplifier do not do as prescribed upon power up, after some 250mS the power supply shuts down.
You know it is the Left Front amplifier that was killed. Replace the output transistors, driver transistors, emitter resistors (if open circuit and follow the set up instructions on page 12 of the manual). It is a very simple amplifier, the uProcessor makes it seem complicated. You could use a power supply to hook onto the amplifier board for testing but ensure you limit the current to a hundred milliamperes or so.
There are a number of Fire Proof resistors so any resistor with the triangle sign may have failed but only on the one channel. Don't get confused!
The schematic is page 9/9 of the schematic section.
You have 250mS to fault find each time.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 9th February 2018, 07:13 PM   #33
SVI2004A's Avatar
Was thinking that.... makes me miss the TA7317P setups
Old 9th February 2018, 07:36 PM   #34
nannoo is offline nannoo
OK guys thanks for putting me in the right direction, turns out as well as TR121 and TR123 it was also TR111 that was causing a short. It's now powering up fine, going to try wiring it up and see if it makes sound/works again
Old 9th February 2018, 07:39 PM   #35
SVI2004A's Avatar
Well the LF channel won’t :P
Old 9th February 2018, 08:10 PM   #36
We're back in business, only 6 channels but who needs 7 anyway
Old 9th February 2018, 08:21 PM   #37
SVI2004A's Avatar
Do turn off amp if changing speaker wiring...
Old 10th February 2018, 01:09 PM   #38
phase is offline phase  United States
My mother had done that to an older Kenwood amplifier, I replaced the mt 200 output transistor and it has been running fine ever since.
HELP HELP HELP - Just blew my amp, can't afford a new one.Hide this!Advertise here!
Can I afford the O-scope/scopes I need? Destroyer OS Equipment & Tools 18 30th May 2017 10:34 AM
Until I can afford a digital unit Old Technics?? Moondog55 Solid State 7 17th November 2012 10:20 PM
Can I afford my SE amp ?? Shoog Tubes / Valves 14 6th December 2005 08:14 AM
I need infos about Threshold SA series (can't afford the XA-200 yet ;-) ) Thurax Pass Labs 3 18th July 2004 07:23 PM
