HELP HELP HELP - Just blew my amp, can't afford a new one.
Old 9th February 2018, 05:53 PM   #21
nannoo is offline nannoo
Ok, on power up it seems that every other amp TP does nothing, whilst there is a very small voltage difference across TP101 - I've tried a few times, readings vary from 0.2 to 0.3v
So I'm guessing that's a clear sign the FL amp is gone?
Old 9th February 2018, 05:54 PM   #22
maybe a silly question, if I remove the power amplifier board with the FL channel, use wire cutters to remove the transistors, can that do any damage to the rest of the amplifier?
I'm wondering if there is a "simplest" way to effectively turn off that channel but return the amp to coming out of protect.
Old 9th February 2018, 05:58 PM   #23
SVI2004A is offline SVI2004A  New Zealand
SVI2004A's Avatar
I would pull out LHS amp bank and check for collector Emitter shorts on output and driver transistors... and R128 130 136 and 138 - there could be an open circuit in them - more so 136/138
I remember when amps were amps & speakers were nervous!
Old 9th February 2018, 06:00 PM   #24
SVI2004A's Avatar
Well you could unsolder the emitters of LHF output transistors- do this while checking for shorts/open... most likely can kill 2 birds with one stone for the now
Old 9th February 2018, 06:05 PM   #25
Starting to feel more confident with the amplifier circuit diagram, taking a look through it looks relatively simple as circuits go, but my expertise doesn't allow me to identify likely candidates for failure, am I looking at the MP/MN 1715's? How do I test them?
Old 9th February 2018, 06:07 PM   #26
OK... So I'm thinking if I remove the 1715's for now and see if it works, then maybe try a new pair in the future? is there a simple way to test them when I remove them? (i.e. continuity tests across terminals?)
Old 9th February 2018, 06:09 PM   #27
SVI2004A's Avatar
Yes check for short pins 2 (Collector) and 3 (Emitter)
Old 9th February 2018, 06:33 PM   #28
All pins shorted on output tansistors.
Removing them now, will update shortly
Old 9th February 2018, 06:44 PM   #29
Removed trannies. Still doesn't allow power amps to kick in.
Old 9th February 2018, 07:02 PM   #30
SVI2004A's Avatar
Aren’t sure how detailed microprocessor analyses this... I would expect these devices to be a Darlington pack - based on 1.2V base voltages...
I would check C-E of tr110 and 112.. - r136/138 may have gone open circuit to protect output of those driver transistors...
You can get the original parts from Denon I’d say, but I’m bettin it wont be cheap... if it were me I would fully turn VR101 counterclockwise and fit 2SD2561 (MN1715) and 2SB1648 (MP1715) and any other parts needing replacement (resistor(s) and drive transistor(s)) then power up and set according to adjustment procedure in manual
HELP HELP HELP - Just blew my amp, can't afford a new one.Hide this!Advertise here!
Can I afford the O-scope/scopes I need? Destroyer OS Equipment & Tools 18 30th May 2017 10:34 AM
Until I can afford a digital unit Old Technics?? Moondog55 Solid State 7 17th November 2012 10:20 PM
Can I afford my SE amp ?? Shoog Tubes / Valves 14 6th December 2005 08:14 AM
I need infos about Threshold SA series (can't afford the XA-200 yet ;-) ) Thurax Pass Labs 3 18th July 2004 07:23 PM
