HELP HELP HELP - Just blew my amp, can't afford a new one.
Old 9th February 2018, 04:58 PM   #11
rayma is online now rayma  United States
Originally Posted by nannoo View Post
I am wondering if my best option is to physically disconnect the power channel that is blown?
Or will that cause the amp to fail again?
That's the easiest option. Do you use more than 2 channels?
Old 9th February 2018, 05:04 PM   #12
nannoo is offline nannoo
I use 6, (main monitors tri amp'd)
But the amp has 7.... so I can get away with losing one. Not ideal but if it's a quick fix it seems like the best solution
There's no voltage on any of the test sites but I wouldn't really expect there to be given that they're set to 0 at factory anyway and there's no way of getting voltage to the amps at the moment.
Old 9th February 2018, 05:06 PM   #13
Project16 is offline Project16  France
Project16's Avatar
I am wondering if my best option is to physically disconnect the power channel that is blown? Or will that cause the amp to fail again?
Follow the instructions of SVI2004A, you will know if the power is defective or not (HS power transistors ).
Edit: We posted at the same time and I did not know your answer.
Old 9th February 2018, 05:13 PM   #14
SVI2004A is offline SVI2004A  New Zealand
SVI2004A's Avatar
No voltage at test points?
Power amp may be ok
The screw terminals off each side of capacitors in centre.. are voltages ok there?
I remember when amps were amps & speakers were nervous!
Old 9th February 2018, 05:14 PM   #15
I need to hold my hands up and say I don't understand.... how can I know if the power transistors are defective if the amp won't deliver power to the circuit?
Old 9th February 2018, 05:15 PM   #16
SVI2004A's Avatar
It makes me wonder... as he has a point...
I would not expect output relays to engage if there was DC present... and he says they engage, then revert to protect
Old 9th February 2018, 05:20 PM   #17
SVI2004A's Avatar
If there was a short or massive dc imbalance, you would see up to 60V at either side to Test point to ground...
Hold - meter Lear to metal base of amp... check on each side of TP - should be 0v
This often triggers protect not to kick in
If there is no dc voltage present, there could be another issue
Old 9th February 2018, 05:27 PM   #18
SVI2004A's Avatar
How is TP301 on centre pcb with caps? Should have 120V measured across pin 1 and 3
Old 9th February 2018, 05:35 PM   #19
I can get a momentary reading from TP301 which drops down pretty rapidly after the relay kicks back out. (i.e. 113V then falls quick)
Old 9th February 2018, 05:44 PM   #20
SVI2004A's Avatar
It may be the cpu is switching main xfmr... check TP101 on power up (to ground) then see what another amp TP does, it’s possible that cpu is waxing power to amp - you might see similar spikes to 56V on TP101 in same duration as TP303 is with 113V
HELP HELP HELP - Just blew my amp, can't afford a new one.Hide this!Advertise here!
Can I afford the O-scope/scopes I need? Destroyer OS Equipment & Tools 18 30th May 2017 10:34 AM
Until I can afford a digital unit Old Technics?? Moondog55 Solid State 7 17th November 2012 10:20 PM
Can I afford my SE amp ?? Shoog Tubes / Valves 14 6th December 2005 08:14 AM
I need infos about Threshold SA series (can't afford the XA-200 yet ;-) ) Thurax Pass Labs 3 18th July 2004 07:23 PM
