Old amp boards unusual topology
Is it worth to fix these old amps? The advantage: nice small boards. Q12 to Q17 sit on a separate PCB the transistors mounted on aluminum profile intended to be mounted on heatsink. The original transistors are either unknown or discontinued for many years thus the simulation is with available and reliable Spice models. I am unsure whether the Wilson mirror (?) makes sense at all.
