SanKen Discontinuing MT200 Power transistors
Old 6th February 2018, 06:44 PM   #11
jaycee is offline jaycee  United Kingdom
Where's the notice of discontinuation ? Cant find anything about it on Sanken's site.
Old 6th February 2018, 06:55 PM   #12
kct is offline kct  Canada
kct's Avatar
I'm glad I picked up a couple not to long ago and almost cleaned out Profusion. They measured quite tight Hfe spread.
Old 6th February 2018, 09:03 PM   #13
SVI2004A is offline SVI2004A  New Zealand
SVI2004A's Avatar
Pdf I have included
I remember when amps were amps & speakers were nervous!
Old 6th February 2018, 09:36 PM   #14
helitim is offline helitim  Canada
Well, this is disappointing. I was hoping to use these in a future project. Perhaps its better to wait and see what options will show up when I'm ready.
Although, it looks like someday in the not so distant future DIY will consist of sending a schematic in and having a discrete IC printed for you(at a price no one can pay). Just add power & ground!
Old 7th February 2018, 12:34 AM   #15
MrMagic is offline MrMagic  Greece
MrMagic's Avatar
Since the big, rounded CRT TV sets were abandoned, a long list of great, cheap high-voltage transistors and other components have been gradually abandoned too. The rest have turned to SMD of course.
SMD has its pros and cons in comparison to through-hole ones. I don't see any other option, than adapt.
A good soldering station with a hot-air pencil and practice, is a must.
Actually, you will only have to "send" a block diagram to your IC printer, and most likely that will be in the near future and you'll be able to print displays too.
The DIY ICs might be much bigger, but functional at a low cost, eg a complete device could be made as a large flat chip up to a printer page -fully integration age with no discrete components whatsoever .
Old 7th February 2018, 02:59 AM   #16
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
They are buried in the list.
Discontinued Products |Sanken Electric
Just IMHO I don't miss the MT200 packages.
One can get roughly 6 pcs of equivalent TO-3P devices for the same price as 4 pcs of MT200, inside it the silicon substrate is still attached onto a TO-3P metal base which in turn is attached to a larger MT200 base, paying ~2 €$Ł more for extra metal and plastic huh?
Borrowing a picture from this link:
2SA1215 2SC2921, identify genuine and fake
Old 7th February 2018, 04:26 AM   #17
sajti is offline sajti  Hungary
I feel too old myself, to work with smd-s. Few is OK, but soldering hudreds of them are out of question. My only way is to stock as much through hole devices as I can...
Sajti
Old 7th February 2018, 07:15 AM   #18
SVI2004A's Avatar
This is from SanKen...
Last orders mid this year
File Type: png 28FE2AB7-A788-4B9F-B8CC-87AEB0F53CC2.png (391.3 KB, 251 views)
Old 7th February 2018, 10:15 AM   #19
wg_ski is online now wg_ski  United States
You would if you were in the business of repairing or restoring old (and good) amplifiers which used them, and had a reputation for doing the job right. That's who needs to be buying them up right now. New construction can always go to new packages or topologies.
Old 7th February 2018, 10:26 AM   #20
thimios is offline thimios  Greece
Measuring hfe in the low current levels doesn't mean something for the high level current where these will be used.
SanKen Discontinuing MT200 Power transistorsHide this!Advertise here!
Nutz, Panasonic is discontinuing my usual power supply caps...viable alternatives? Russellc Pass Labs 24 21st July 2015 06:12 AM
Sanken Genuine TO3 Power Transistors for Sale Zeljko Swap Meet 9 17th July 2014 06:16 PM
Sanken Transistors Kermit100 Parts 2 1st April 2013 11:47 AM
Naim PC boards and Sanken power transistors for sale gaborbela Swap Meet 2 16th November 2008 04:09 PM
FS: Sanken 2SA1216, 2SC2922 power transistors len_scanlan Swap Meet 1 13th January 2006 04:41 PM
