Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old 25th July 2018, 04:09 AM   #2731
Kokanee is offline Kokanee  Canada
Kokanee's Avatar
Thats a tough one, X. I have been through this with relatives. Learned a lot about putting a basement back together. Good luck.
McD
Old 25th July 2018, 10:06 AM   #2732
tonza75 is offline tonza75  Nauru
Happened in past to me/ family similar situation. It sucks hope all dries up ASAP.
Old 25th July 2018, 02:22 PM   #2733
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
It’s amazing how many people have also gone through this type of a home disaster. You would think water sensor alarms would be standard requirement (like a smoke detector). I just bought 8 of them and will place them wherever a leak can happen (under each sink, washer, dishwasher, water heater, and of course sump pump).
Thanks for all the moral support!
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 26th July 2018, 06:31 AM   #2734
wtl is offline wtl  Australia
Sorry to hear of your misfortune X.
On a lighter note I checked the rail voltage on my Alpha 20.
I get 23.5 v using 18v 350va transformer per channel .
Steve.
Old 27th July 2018, 07:29 AM   #2735
alibear is offline alibear  United Kingdom
alibear's Avatar
So sorry to hear of your problem X , hope you get back to normal soon.
Your help, encouragement and support has been appreciated by so many on the Forum. All the best
Alan
46 The GOAT -- never doubt !
Old 27th July 2018, 04:08 PM   #2736
prasi is offline prasi  India
prasi's Avatar
sorry to hear x, that's tough luck. hope you get your workshop up and running soon.
regards
Prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 27th July 2018, 06:41 PM   #2737
Got Foam?
xrk971's Avatar
Thanks for the support guys. The cleanup and drying has been completed. Now moving on to renovation by installing carpet and drywall that was removed. I am also going through personal effects that were wet to see if damaged. But the lab is going to be at least 2-3 weeks before back to normal.
Old 11th August 2018, 12:53 AM   #2738
stellarelephant is offline stellarelephant  United States
stellarelephant's Avatar
I know there has been some discussion about filtering power for the Alpha cooling fans. Perhaps the usual strategies are already plenty effective, but I just came across this purpose-made module and thought I'd share it.
Old 11th August 2018, 01:03 AM   #2739
Got Foam?
xrk971's Avatar
I am using one of JPS64’s CLC filters from the Aksa Lender Preamp. I have a 1000uF // 1mH ferrite core // 1000uF cap with 51R in parallel across the inductor. It stopped the fan noise dead. If you look at JPS64’s layout for Alpha BB you will notice a built in CLC in the main board for the fan controller power supply.
Thanks for the link to that fancy CLC filter though. It looks like some nice components used genre.
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 780 Yesterday 03:58 PM
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 399 26th June 2018 10:26 PM
Aksa Lender HPA xrk971 Headphone Systems 40 12th June 2018 02:06 AM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 03:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 03:05 PM
