Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old 18th July 2018, 05:31 PM   #2701
gaborbela is offline gaborbela  Canada
With the 22V transformer, you get 26.4V plus U use CRCRCRC power supply. With the 3pc R you burn up some power also. I hope you not using any high-value resistors there to burn up more power. Your 25.6V is absolutely normal with your setup.
When you buy a transformer to regular Class A bias calculation(not talking about Alep X where the total bias is over 7A per channel) 22ACV x 1.2 under load =26.4V DC.
Old 18th July 2018, 05:56 PM   #2702
tonza75 is offline tonza75  Nauru
I think you know better and waiting for someone to answer.
Old 18th July 2018, 07:13 PM   #2703
Juntuin is online now Juntuin  Finland
B.B. one channel: 39,7vdc under load. 2x30vac sec 545va trafo. Can't remember or measure Alpha20 right now..
Old 18th July 2018, 08:57 PM   #2704
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I am using 0.15R - ok so normal. My problem is that I have been using 1.4x and subtracting 3-4v for load. But 1.2x multiplier seems way to go for Class A. My CRCRCRC burns off 1.2v.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 18th July 2018, 09:28 PM   #2705
Oh, forgot that CCRCCRC where 0.2ohm per resistor.
Old 18th July 2018, 10:10 PM   #2706
fab is offline fab  Canada
fab's Avatar
Originally Posted by xrk971 View Post
I recently bought a pair of 22VAC 300VA Anteks, hoping to get a solid 27vdc under load of 1.6amps. After the CRCRCRC, I am getting 25.6v. This is for a high output variant of the Alpha 20 that I am testing - just seeing if pushing higher voltage and increased cooling via CPU coolers and fans can work to boost power output.
Hi X
Antek supplier specifies output voltage under specific load current (not much data though) with 120vac input. In my area line voltage from provider can vary from 115 to 122vac (I have a real time indicator) in normal situation (not too cold/hot weather). Mostly depends on time of the day with demands from all houses/buildings.
Also, rectifier diodes have different voltage drop depending on their temperature. Check the specific data sheet of your diodes.
And then you add the voltage drop of the resistors in series in your PSU.
Fab
Old 18th July 2018, 10:32 PM   #2707
Vunce is online now Vunce  United States
With my 600va, 32v transformers, my BB’s are running at 37.5vdc with a CRCLC. If I use a capMx instead of the CRCLC the voltage increases to 38vdc.
Since it’s summertime, my line voltage varies widely during a 24 hr period. Anywhere from 112vac to 125vac.
I think my ALPHA20 is running 23vdc, I’d have to check (don’t remember).
I did notice that the DC offset increased from 10mv @36vdc to 25mv @37.5vdc?
Old 19th July 2018, 01:31 AM   #2708
Got Foam?
xrk971's Avatar
Hi Vunce,
You must have some big power with 37.5v rails. I am guessing upwards of 70w? You have these 99dB Klipsch speakers so would never know what 70w feels like on the B.B.
Old 19th July 2018, 02:45 AM   #2709
Exactly X
My Forte’s play incredibly loud with the ALPHA20. The appeal about the BB is that I get to use a powerful Class A amp with much less efficient speakers that I have.
Old 19th July 2018, 04:56 PM   #2710
Got Foam?
xrk971's Avatar
This looks like a nice case for an all fan-cooled Alpha. Very IT looking but nice airflow grill holes and built in flow thru fans (which I will drop the speed on).
Amazon.com: Rosewill 4U Server Chassis / Server Case / Rackmount Case, Metal Rack Mount Computer Case with 8 Bays & 4 Fans Pre-Installed (RSV-R4000): Computers & Accessories
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 778 14th August 2018 05:25 AM
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 399 26th June 2018 10:26 PM
Aksa Lender HPA xrk971 Headphone Systems 40 12th June 2018 02:06 AM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 03:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 03:05 PM
