Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old 10th July 2018, 08:04 PM   #2691
zman01 is offline zman01  Bangladesh
Juntuin,
Very nice work with the build! Congratulations on the successful execution of some bold design ideas.
Old 10th July 2018, 08:09 PM   #2692
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
It is the Patek. We don't hear from Peter Daniel anymore...
PREAMPs : AMB α10 + USSPA | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA BII + OPC's NTD1 I/V | Signalyst DSCv2 | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 10th July 2018, 08:11 PM   #2693
Vunce is offline Vunce  United States
X,
I believe that is a chipamp/ gainclone type of build.
Oops, I didn’t refresh page. Yeh, what you guys said:-)
Old 10th July 2018, 08:15 PM   #2694
Juntuin is offline Juntuin  Finland
Originally Posted by zman01 View Post
Juntuin,
Thanks Z, sides will get trashed tough and something else is coming as replacement but even then, this is not the most conservative build..but neither is the B.B., it's rather something old combined to something new.
Old 10th July 2018, 09:33 PM   #2695
wtl is offline wtl  Australia
Juntuin,
First Class Build!!!!
Steve.
Old 10th July 2018, 11:44 PM   #2696
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
A gainclone built like a Class A. Nothing against chipamps here, just so much more fun to make discrete amps.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 12th July 2018, 09:53 PM   #2697
Got Foam?
xrk971's Avatar
This is interesting. Matched PNP in SMT package.
https://www.mouser.com/datasheet/2/3...6-D-775558.pdf
Although specs say current gain matching to within 10% whereas we hand match Hfe to typically 1%.
KSA992 also available in SOT23 package - it’s called FJV992MTF.
https://www.fairchildsemi.com/datasheets/FJ/FJV992.pdf
The KSC1845 is available as SOT23 and called FJV1845PMTF
https://www.fairchildsemi.com/datasheets/FJ/FJV1845.pdf
The front end of the Alpha and the Aleph CCS could theoretically be shrunken down to the size of large postage stamp if all SMT parts were used.
Old 13th July 2018, 12:03 PM   #2698
tonza75 is offline tonza75  Europe
Default The front end of the Alpha and the Aleph CCS could theoretically be shrunken down to
This is true it's a postcard from the past passed last labs.
Old 13th July 2018, 04:35 PM   #2699
Got Foam?
xrk971's Avatar
The Aksa Lender preamp daughter cards are essentially the front end, but maybe about size of 4 postage stamps. This one is on a metal core PCB.
Old 18th July 2018, 03:54 PM   #2700
Got Foam?
xrk971's Avatar
I am curious what rail voltages builders of the Alpha 20 and Alpha BB are actually running at? There is a large amount of voltage sag with linear trafos and it seems to me, no matter how I try, I end up always a volt or two below recommended rail voltage. Also, if you are above, is the heat output manageable?
I recently bought a pair of 22VAC 300VA Anteks, hoping to get a solid 27vdc under load of 1.6amps. After the CRCRCRC, I am getting 25.6v. This is for a high output variant of the Alpha 20 that I am testing - just seeing if pushing higher voltage and increased cooling via CPU coolers and fans can work to boost power output.
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 795 Today 05:37 AM
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 399 26th June 2018 10:26 PM
Aksa Lender HPA xrk971 Headphone Systems 40 12th June 2018 02:06 AM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 03:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 03:05 PM
