Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old 23rd June 2018, 04:47 PM   #2591
hajj is offline hajj  Lebanon
hajj's Avatar
Has anyone tried an LT1083 based PSU?
They are good for 7A, and one could easily build a bipolar supply using two of them.
Nick
Old 23rd June 2018, 11:11 PM   #2592
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Yes, it should work but will still require some fairly large capacitors to smooth the ripple before being fed into the the regulator. You should try it and report back to us.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 23rd June 2018, 11:19 PM   #2593
hajj's Avatar
I just happen to have two LT1083 boards I had bought for a different project. Might as well use them for my ALPHA build
Ripple rejection is quoted at 75db at 120hz, and would be at 83db at 2A load, is that enough?
Nick
Old 23rd June 2018, 11:46 PM   #2594
AKSA is offline AKSA  Australia
Absolutely Nick. Go for it!
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old Yesterday, 01:16 AM   #2595
Vunce is offline Vunce  United States
Originally Posted by Vunce View Post
I also put the Fo-Felix EMI Filter for AC mains 120/230v; By Folsom, into the mix. I am pleased to say that this filter eliminated almost all the “extra” noises/buzzing I was hearing close to the speaker.
I kept investigating and found that the “extra” noise stopped when the fans were turned off. After a conversation with X, I installed a CLC filter I had from the AKSA Lender Preamp between the wallwart psu and the PWM fan controller. This combination worked very well to quiet the remaining “noise” I was hearing.
File Type: jpg 3EA8531B-DA65-417C-8E8F-C9ECFA9BA453.jpg (575.8 KB, 134 views)
File Type: png 2533DDA5-93FD-4B50-9412-7EA0B2B8583F.png (149.7 KB, 130 views)
Old Yesterday, 02:28 AM   #2596
Got Foam?
xrk971's Avatar
Nice result, Vunce. I noticed that JPS64 adds these CLC’s upstream of any pulsed digital system such as DC-DC or PWM modules. It seems to do the trick here doesn’t it? What’s odd is the Fo-Felix did not stop this from coming up from the mains.
Old Yesterday, 03:02 AM   #2597
JPS64 has the right idea, it worked for my setup.
The Fo-Felix is filtering the mains for the Alpha BB only, the psu for the PWM controller and fans is not connected to the Fo-Felix.
Old Yesterday, 10:16 PM   #2598
gaborbela is online now gaborbela  Canada
Hi guys
I would love to ask a big favor from someone US (resident)or has US shipping address.
I found some parts for my TV at the US eBay, unfortunately, the seller does not ship internationally (Canada). He does not set up to do that so he politely rejected my offer. Can someone help me with these before he will sell his parts?
Not that giant parts but without those, I cannot fix my TV and now I just can NOT purchase a NEW TV. Please contact me via PM.
Thanks very much. I was meditating on these almost two weeks until I took the courage to ask... Unfortunately, I don't have any relatives or close friend to ask for.
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 626 20th June 2018 12:05 AM
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 398 15th June 2018 07:10 PM
Aksa Lender HPA xrk971 Headphone Systems 40 12th June 2018 02:06 AM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 03:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 03:05 PM
