Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old 9th February 2018, 12:11 AM   #251
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
PCB shipment has arrived at DHL hub in Cincinnati OH - delivery by evening tomorrow.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 9th February 2018, 02:40 AM   #252
pcgab is offline pcgab  United States
Wow, that's fast production!
Awesome news X!
Old 9th February 2018, 02:52 AM   #253
bk856er is offline bk856er  United States
bk856er's Avatar
pcgab, your BOM was helpful. Is the 2/2 version still current?
BK
Old 9th February 2018, 02:12 PM   #254
The BOM I attached in post 199:
X can answer better than I certainly. The above is the BOM I used to order. I haven't assembled a prototype and will likely wait for the boards to arrive as they're already shipped to X.
Old 9th February 2018, 07:19 PM   #255
X, hugh, et all:
For C101, would a 330pF 100v FKP2 be ok?
Schematic calls for 220pF. I have 330pF on hand if it will work.
~Gable
Old 9th February 2018, 08:06 PM   #256
Got Foam?
xrk971's Avatar
That should be fine. It’s an RF interference filter so you can calculate cutoff frequency with 2k2 in series. 330pF gives 220kHz - should be fine to let high slew rate audio through and keep out RF.
Old 9th February 2018, 08:16 PM   #257
Awesome, thank you X!
Old 9th February 2018, 08:34 PM   #258
BK
I may have missed this in the bom:
C115 1uf 63v MKS4
Looks like the same cap as C121
Old 10th February 2018, 04:25 AM   #259
Got Foam?
xrk971's Avatar
C115 1uf 63v MKS4
Yes, both of those are 1uF MKS bypass caps for the big electrolytics.
The PCBs that JPS64 designed look great. Perhaps one of the prettiest PCBs I have seen. The double thick copper with ENIG finish and blue solder mask work real well together on 2mm thick board. But the star of the show is the crazy intense number of vias that connect parallel thick traces on both sides of the board for the high current flows and the ground plane.
Here are some photos of the boards and a closeup of the backside. I am afraid to ask how many vias that is and how many drill bits may have been used to make all of them?
Top and bottom side:
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier-alpha20-pcb-sample-jpg
Closeup of back side:
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier-alpha20-pcb-closeup-jpg
JPS64 put some reallly nice touches on it: one of my favorites is the choice of spade connectors or flying leads (for the Pass forum diehards) for the power supply and speaker output connections. UMS compliant MOSFET and standoff positions is also another great feature. Options for NP0 SMT caps or silver mica on C105 and C113 are also great choices to have. Nice job JPS64! "
Old 10th February 2018, 04:32 AM   #260
zman01 is offline zman01  Bangladesh
That's a good looking PCB, X!
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 718 21st July 2018 06:59 AM
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 399 26th June 2018 10:26 PM
Aksa Lender HPA xrk971 Headphone Systems 40 12th June 2018 02:06 AM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 03:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 03:05 PM
