Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old Yesterday, 05:29 PM   #1901
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by sarathssca View Post
Does this amp needs a linear power supply or does it work with SMPS also, especially the 20w version? Most of the builds looks to be using the linear power supplies here.
Both Vunce and I tried SMPS and cap Mx with the Alpha, but with the SMPS supply I had, it seemed to be not happy providing the combined 2.7amps at +/-24v even though rated for 5amps. Also going through the cap Mx with 2.7amps and 4.5v drop was 12w dissipation per channel in the cap Mx (if using MOSFETs). It can work - as I have shown it works on the M2, without a cap Mx but a CRC. So I think maybe get a big powerful 10amp capable SMPS and should be alright.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old Yesterday, 06:30 PM   #1902
irribeo is offline irribeo  Netherlands
Maybe use the Evil cap Mx, like the "copied" half one Allo is selling for single voltage. (Allo uses 100% identical parts and circuit as in Simplified Evil cap Mx).
Old Yesterday, 06:39 PM   #1903
tonza75 is offline tonza75  Finland
I run a quick test, through regulated dual 10A 30V lab supply I need to inspect the the diode the bc 547c the ltp vbe of track about 10mV- 20mV of. Need to inspect the diode and KSC1845fta.
I did a stimulation over 900 in a row with relevant spice variables. As Mr. Xr stated put the lid on remeasure.
This on is a somewhat picky. Know wonder it taken months of work for some here. To get stable. Mr. Xr please explain your process to near 0 dc/ac start up cold to warm lid on lid off. You built many, this is your expertise area so share
Old Yesterday, 07:51 PM   #1904
Got Foam?
xrk971's Avatar
Hi Tonza,
So you finished building the Alpha and are now testing? The 10mV to 20mV is well within "normal" range for the DC offset and it should not vary greater than that over cold to hot with lid on or off. I did not do anything special - just matched the Hfe on the LTP and have them thermally bonded to each other via shrinktube (no thermal compound paste even). Hugh explained that my 0mV was purely coincidence as the sum of all the voltage drops across the LTP/VAS and CCS and outputs, on average, added up to be zero due to statistical variances washing out. If you are at 20mV, it should remain at 20mV hot or cold if LTP's are thermally bonded together.
You could a different N-channel MOSFET with slight up/down Vgs to "tune" your DC offset but I would leave it alone if you are under 30mV which is nothing on an 8ohm speaker (0.7mW).
Old Yesterday, 08:20 PM   #1905
Vunce is offline Vunce  United States
My ALPHA20 dc offset is:
Channel 1 is 12mV
Channel 2 is 17mV
Old Yesterday, 08:33 PM   #1906
Hi Tonza,
Yes i have them bonded i tried them thermally with a resistance wire flat, kapton around to about 60 degres celcius on a breadboard to match them . But i measured on pcb the ksa992 from pins base emitter the off 10-20mV of . Problem is AC out 1.7V not good at all input shorted . I got the dc down to 8mV . I won't connect a loudspeaker you now know why.
I'll try tomorrow . Bed time .
Old Yesterday, 09:03 PM   #1907
Got Foam?
xrk971's Avatar
1.7vac is indeed a problem. Please mark up schematic with parts substitutions you may have made and DC voltages at all nodes of the actives for us to help debug. What is your bias current? A closeup photo or two is also very helpful.
Old Today, 12:30 AM   #1908
AKSA is offline AKSA  Australia
Hmmm. A few issues with offset, and AC output at zero signal.
OFFSET:
Offset should be within +/-25mV. Within these limits, all is acceptable.
To put this into perspective, a 100mV offset, a huge figure you almost never see, creates 100/6.8 = 15mA of standing current through the voice coil of a WOOFER (not a mid or tweeter because with a passive crossover both has a cap in the HP filter blocking this current). This 100mV offset dissipates 1.47mW. Since the minimum a voice coil can dissipate is typically 10W, 0.00147W seems trivial - AND IT IS!! Keep the offset within +/-25mV, but do not obsess about getting it down to 1mV. It is not necessary, it is unusual, and it has no effect on sound quality.
Offset is controlled by three factors:
1. Stage Current. This current is passed from the two resistors and pot from the positive rail and filtered by C103, the 1000uF (Refer #111 from XRK on 2 Feb 2018). On the ALPHA it should be 2.05mA. You can measure this on the pot provided at R105. A 100R change on the pot will alter offset around 2.5mV, and raising this resistance brings UP the offset, from -2.5mV to 0mV. This is sole adjustment on this amplifier.
2. Offset is controlled from the long tailed pair (LTP) which seeks to hold the base potential identical for both V101 and V102. The differential action relies upon identical Hfe (beta) for the two transistors and significantly the voltage between base and emitter at the identical collector current, which should be 1.025mA for each transistor.
Therefore since both transistors both require a small base current, typically around 1.025mA/beta, maybe around 7uA assuming 145 of beta for both of them. So, you have to supply this small current, on the left (input, V101) transistor it is supplied from R102, the 22k resistor to ground, and on the right (fb, V102) transistor is should be the same 7uA base current but will be supplied from R113, the series fb resistor f 22k. Note that R102 and R113 are the same 22k resistor value. You can replace this value to 18k, or even 10k, but BOTH RESISTORS MUST BE IDENTICAL.
3. The final adjustment for offset is controlled by the pot, R105, but to be really accurate both LTP transistors, V101 and V102, should be MATCHED for BETA and Vbe at 1mA.
Therefore to work correctly and reveal a magnificent 0mV offset, you have to match the LTP transistor not just for beta, but also for Vbe at 1mA, the prevailing current for each when fully balanced.
This is difficult because matching transistors is expensive and not required. You should simply use two transistors from the batch and hope they are close, then trim the R105 pot to achieve 0mV at the output. And don't be too OCD about this, within +/-25mV is good enough and will NOT affect the sound quality.
As for the 1.7Vac Tonza has on his ALPHA I'm baffled. Are they both the same? How are they measured? Is it all hum/buzz or is it broadband noise? What is the quiescent current on the output stage?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old Today, 01:56 AM   #1909
Aatto is offline Aatto  United States
Aatto's Avatar
Finally in progress... those are the biggest caps ever.
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier-unnamed-jpg
Old Today, 03:38 AM   #1910
Got Foam?
xrk971's Avatar
You ain't kidding - those are the biggest 10uF box caps ever.
Looking good.
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 575 24th April 2018 07:38 PM
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 388 19th April 2018 02:07 PM
Aksa Lender HPA xrk971 Headphone Systems 26 28th March 2018 04:14 PM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 03:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 03:05 PM
