Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Solid State Talk all about solid state amplification. |
#1851 | |
How about bc 547c what did you choose here in final ver. Thanks. |
#1852 |
Got Foam?
Watch the leg pin orientations. On BB, the KSC3503 TO126 was used. The BC547 on the Aleph CCS is of no consequence. Almost any NPN in the same family can work assuming max ratings are not exceeded. BC546/7/8/9/550 can probably all work.
http://www.mouser.com/ds/2/149/BC547-888524.pdf
XRKaudio https://www.etsy.com/shop/XRKAudio |
#1853 | |
Many amps built when I was younger and had the passion, not so active as repair jobs takes time amps too but more computer, mobile, consumer device maintenance. |
#1854 |
Not a bad idea to standardize scoring for audio systems. However I have to point something out.
I've listened to multiple systems separately and at the time I rated them fairly well. But then over time it becomes clear one of them is really not that good. I think this is due to reference point shift. When we say something is "good" we are always determining that based on prior experience, with a bias toward recent events. If the reference points shifts, then a scoring system such as this will tend to give flaky results. Thus it would require either a very experienced reviewer to score accurately or it would require scores to be made based on comparisons rather than plucking a number form the top of your head that "sounds about right". So when I try to rate equipment from now on, I don't try to say something is good or bad. The most meaningful comparison I can make is to rate it as better or worse than something specific I've already listened to. This also forces you to organize your experience in terms of sound quality, which helps as rudimentary error prevention mechanism. There are certain quality milemarkers as well. For instance can you hear the Ds in a choral latin piece? Maybe you can even tell what they're saying? Can you tell when the pianist plays two notes but releases one sooner? When testing changes on a system I'll often notice that certain consonants become more legible and I can then hear the lyrics better in some tracks. These are things I take note of which seem a bit more solid than rating a system by choosing numbers. Numerical ratings are a very slippery kind of rating and in my experience they often fail, and rely too much on the operator being consistent in eyeballing those numbers. Rating with a hierarchy rather than an arbitrary number system has the benefit that you are not presuming the limits of quality by rating something high; you can always put something higher at the top without having to go above 100% or split the top 99% into 99.1%, 99.2%... What do you do when your 96% from today seems more like 60% after listening to a different system? I don't like the percentages, I would rather just say X is better than Y, and Y is better than Z. And with Y you can hear the quiet choral Ds, but with X you can hear those and ALSO understand clearly what they are saying - in Latin. Another weakness of rating systems is when a system sounds so good, you don't know how to make a valid complaint against it.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer! Need something built, repaired or modded? PM me and ask what I can do! |
#1855 |
I really like the idea of a numerical rating system as an attempt to quantify the subjective qualities of an amp. What a useful metric for somebody like me who is trying to pick an amp to build from the dizzying array here on DIYA.
Yet I can see Keantoken's point, too. We all have different reference points based on what we have heard before, and especially what we have on hand to make direct comparisons with. Perhaps each reviewer's total score should be weighted based on the total number of amps he has owned, before his score gets rolled into a group average. Lol. No, more likely we will just use our own discretion for deciding whose reviews we trust the most. |
#1856 |
Yes, Stellar, I agree. I can see Kean's reasonable comments, yet, I am trying hard to objectivise the subjectives using a 'global' system which can be argued either way but should give a reasonably predictable figure related to the sound quality. This is an absurd game, I recognise, but we have to do this eventually since THD is a poor indicator of sound excellence.
Gedlee proposed a more objective system with his index, but it's not come off yet, this is a simple attempt to pick off the issues that make a audio playback system 'musical', whatever the hell that is....... groan....... Hugh Last edited by AKSA; Today at 12:04 AM. |
#1857 |
Hi
Can the mentioned Fairchild mosfet be used without any negative sound or performance effect in the Alpha? I will (want to) increase the current ratings to able to drive 4R speakers. The IXYS overkill for that and just too expensive. |
Thread | Thread Starter | Forum | Replies | Last Post |
AKSA's Lender Preamp with 40Vpp Output | xrk971 | Analog Line Level | 575 | Yesterday 07:38 PM |
AKSA's Lender Preamp with 40Vpp Ouput GB | xrk971 | Group Buys | 388 | 19th April 2018 02:07 PM |
Aksa Lender HPA | xrk971 | Headphone Systems | 26 | 28th March 2018 04:14 PM |
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? | klykx | Full Range | 1 | 9th October 2006 03:22 PM |
AKSA vs Aleph or Aleph-X | Prune | Pass Labs | 20 | 11th March 2004 03:05 PM |
New To Site? | Need Help? |
