Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old 13th March 2018, 11:47 AM   #1081
irribeo is online now irribeo  Netherlands
I am interested in which Pmosfet pcgab and Vunce used.
Old 13th March 2018, 12:30 PM   #1082
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I am guessing Vishay IRFP9240?
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 13th March 2018, 12:39 PM   #1083
Vunce is offline Vunce  United States
This is what I used:
https://www.mouser.com/ds/2/427/sihfp924-70303.pdf
Old 13th March 2018, 01:47 PM   #1084
pcgab is offline pcgab  United States
I used the usual 9240/240 combo. Matched for vgs between pairs and channels.
Old 13th March 2018, 01:59 PM   #1085
Somebody already finished ampboards with Ixys or OnSemi Pmosfets ? For 9240 there have been some treble critique in other amps if I remember correctly ?
Old 13th March 2018, 02:22 PM   #1086
Juntuin is offline Juntuin  Finland
One with ixys firing up today..hopefully not literally.
Old 13th March 2018, 02:39 PM   #1087
Got Foam?
xrk971's Avatar
Good luck! Fingers crossed - but this amp is pretty safe and calm during initial turn on from the examples I have seen.
Interesting to see how the IXYS sounds. Which parts did you get?
Old 13th March 2018, 03:21 PM   #1088
It seems so measurements seems to be ok, 0.6v across R131 and very little dc on output.
IXTQ36P15P and IXTQ36N30P.
I was wondering that do I have enough pressure on mosfets, since plate that pushes them on copper/heatpipes gets hot like hell very quickly, while heatsinks don't heat up so quickly.
Old 13th March 2018, 03:59 PM   #1089
Got Foam?
xrk971's Avatar
Are you using silicone heat sink spacers? I do find that torquing the bolts that clamp the MOSFETs down was important. One time I did not do it tight enough and smelled the funny “hot electronics smell” the one before puff of magic smoke occurs. I pulled the power off and discovered a loose bolt.
Tighten the clamps some more is all I can say. The clamps will get hotter because the heat to the sink and heat pipes gets dissipated very efficiently. Whereas the clamp has only slow local conduction. It may be fine. Do you have an iR thermometers? Measure MOSFET package temp.
Ok, hooked up speakers yet?
Another safe and uneventful adjustment-free Class A startup courtesy ALPHA topology.
Old 13th March 2018, 04:12 PM   #1090
Jazzfan is offline Jazzfan  Canada
X
I have a balanced system. Is there any way for me to get in on the fun.
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 589 Yesterday 06:57 PM
Aksa Lender HPA xrk971 Headphone Systems 31 18th May 2018 05:43 PM
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 389 8th May 2018 03:52 AM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 03:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 03:05 PM
