Hi!
I'm wondering if anyone can help me with resistor values for this volume attenuator. I'll command it with 4 bit to have 16 levels. So, having the fisrt 10 levels with small difference, say 1 dB and the others from 3 dB, how can I figure out the resistors values? Any formula?? Or I must use the ohm's law? Thanks in advance Pedro Martins |
#2 |
The parcial schematic
#4 |
#5 | |
I'm updating the layout, sorry... When I'm finished, I'll send a mail to you |
#6 |
Here is some values:
Please comment. This gives a 22k load to the preamp |
#7 |
Banned
This Looks Interesting
#8 |
Guys,
I'm going to use the attenuator with 6 4067 to control a 5.1 preamp using one control unit. This is only because I've got a log of PGA2310 and some PIC's but I still can't learn how to program them Do you think it is a good second solution? |
#9 | |
Banned
You can simply use my code to controll the PGAs. At the moment i make a version for 16F877, for 16F628 you find here: http://home.tu-clausthal.de/~tpa/PGA/03.asm |
#10 |
I made some volume controll with 4067, even 256steps, with two units
It works well, but for low distortion use very high input impedance buffer for it. I used two opamps (one between the two 4067) with gain of 1, non inverting, with 330-470kohm resistor between the +input and the gnd. Some muting is also necessary to avoid switch noises.... sajti |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| What POT for Volume Control? | delamancha | Chip Amps | 3 | 4th February 2008 09:07 AM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| The remote control paratactic volume control | audio-gd | Solid State | 33 | 7th June 2007 11:16 PM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Page generated in 0.11869 seconds (72.36% PHP - 27.64% MySQL) with 11 queries |
