Marantz PM 80 mk2
Marantz PM 80 mk2
Old 9th January 2018, 09:49 AM   #1
Joanito is offline Joanito  Portugal
Default Marantz PM 80 mk2
Hi all,
I am considering simulate one channel of this amplifier in LTSpice. I've been seeing the technical details of this amp and i also want to know more about it.
Here is a link to service manual download:
Marantz PM-80-Mk2 Service Manual, Service Manual, Repair Schematics
The amplifier operates in both classes ( AB and A ). It even has a button to do the switch. What i understand after i saw the service manual is that: when it operates in class A, the voltages in the rails must drop to 24.9v and -24.9v, correct ?
So i can see the power supply providing the correct voltages... :
... But i don't see the power supply providing the 24.9v and -24.9v. And i can see the button to switch classes in the schematic but i don't understand how this circuit works... After all this voltages must come from somewhere, right ?
Or the voltages in the rails, when switched to class A, remain +56.7v and -57v, but what they mean is that they can be reduced to 24.9v and -24.9v if we want, is that it ?
Thanks.
Old 9th January 2018, 10:04 AM   #2
Is this a very good amplifier ? It claims to have a very low THD value considering other comercial amplifiers. Would that THD be true ?
Thanks.
Old 12th January 2018, 06:43 AM   #3
chermann is offline chermann  Austria
Hello
i got the manual from this page
Download Marantz PM-80 Service Manual
If you look at Page 10 you will see the connection to the switch (Class a switch) PSIO (board) JSI2. If you press this Clss A botton the ralay (L851) is switching its 2 conntact and the power transformer provide you the "magic" 17.3V AC -after filtering you get about 20.5VDC.
Maybe in the future this relay contact get worse...so you have to change the relay because the contact ar gone.
regards
chris
File Type: png Class A_Power Rail for Marantz PM 80.PNG (887.0 KB, 108 views)
Old 12th January 2018, 09:48 AM   #4
cumbb is offline cumbb
cumbb's Avatar
"Is this a very good amplifier ?"
No;-)
different/relative,-)
Old 12th January 2018, 10:21 AM   #5
give it a try
...if you want to pimp this old amp then try to change the PSU electrolytic caps and then the others...first electrolytic.
I did that for my 28 years old Preamp Accuphase C200V and it worked perfectly! Watch out the polarity and the size of the caps in some area !
greetings
chris
Old 12th January 2018, 12:31 PM   #6
Thanks guys,
...So if i want to simulate one channel of this amp operating in booth classes in LTSpice, i just have to replace like this:
... and the new switch defines if we want it operating in class A or in class AB ?
Is that it ?
Old 12th January 2018, 03:46 PM   #7
Originally Posted by Joanito View Post
Thanks guys,
Attachment 656333
Is that it ?
sorry ..i dont get your point. What do you want with the left drawing? it looks to me like a opto coupler.You want to change this to a switch??
Old 12th January 2018, 04:17 PM   #8
Yes, that opto coupler closes or open the circuit that defines class A or class AB, right ? Can i do it ? ( i mean the repleacement ) ?
Old 12th January 2018, 07:50 PM   #9
hmm looks not bad... should work....
but why change the switching function? try in clss A for listening and for party mode release the button
Old 12th January 2018, 08:52 PM   #10
Because it would be my first constructed and simulated circuit in LTSpice and i'm afraid i can't found opto couplers in component menu :-D . And i i'm not very experienced with LTSpice also and replace the opto coupler by a switch makes circuit more simple...
Thanks.
Marantz PM 80 mk2Hide this!Advertise here!
Marantz CD94 / Marantz CD 65 Gold -- What DAC? poynton Digital Source 5 25th August 2017 01:07 PM
marantz alft333 Everything Else 0 3rd June 2010 04:00 PM
Right speakers for Marantz PM8000 + Marantz CD67-OSE? betto80 Multi-Way 2 24th May 2005 03:21 PM
Link Between Marantz CD12 and Marantz CD99 Mesh Digital Source 16 7th November 2003 06:08 PM
Marantz T-1 stigla Tubes / Valves 4 17th October 2002 01:11 PM
