Hello,
My amp need 50-0-50 Vac transformer but I have 25-0-25 VAC two units in hand. Does any one has an idea to reach my taget? Is there any problems if I try this |
#2 |
Looks different.... Shouldnt you connect your "virtual center taps" from the Toroids to the Gnd instead of creating a Quad like gnd from the main caps?
basically the "D" of Toroid 1 will be connected to the "A" of Toroid 2 to make your center tap or gnd.... D |
#3 |
The transformer wiring looks ok to me (as long as you really are planning to use two bridge rectifires, not one) , but I think you have the bridge rectifiers wired incorretly.
The negative of the top bridge should connect to the positive of the bottom bridge..... that's all Steve |
#4 |
Oh yes, negative of top bridge connected to positive of the bottom one. How much VA I should get if each one has 350VA? |
#5 | |
You will have the equivalent of one 700VA 50-0-50 transformer.. |
| Power supply:Universal AC input/ Full range,High Efficiency, and High reliability | hang | Vendor's Bazaar | 12 | 24th July 2009 03:46 AM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 08:05 PM |
| high DCR secondary (power transformer) | jarthel | Tubes / Valves | 2 | 16th June 2007 09:44 AM |
| High Power - Output transformer | h_andree | Chip Amps | 8 | 2nd March 2004 05:45 PM |
| Page generated in 0.07507 seconds (79.53% PHP - 20.47% MySQL) with 11 queries |
