So you need to apply the same signal to both channels and use your scope to look at the signal directly on the base of H702.
You should see identical signal levels for both channels. Remember there will be a slight DC offset on the base but the signal will be superimposed onto that.
Hi Mooly, It has been a while, Have not done much with my audio gear we sold our home at the end of Feb. and had to find a new place to call home, well low and behold we are in our new place and getting settled in. I plan on returning to my 2250b, I did go through to familiarize myself were i left off. I remember having that tinny sound on the left channel, I believed i narrowed that down to the tone board, after recapping the left main amp i fed my phone through it to play music through the main in (inputs) and clear as a bell, so i thinking it is the tone board. I do not have my work station at 100% at this time still need some time but i am itching to get back to this unit
Pat
Pat
- New Project Marantz 2250b
