old Pioneer sa-5300
old Pioneer sa-5300
Old 5th April 2004, 01:29 PM   #1
Matt Neilson is offline Matt Neilson  Australia
Default old Pioneer sa-5300
hi, i have an old pioneer sa-5300, which used to sound great until about 5 years ago when the left channel crackled, causing the channel to completely turn itself off, and then on again, it also doesn't have as much grunt as it did before, i was wondering if anyone has any ideas as to what parts to replace to bring this baby back to life, and if possible any modifications to make it better than it ever was!
Old 5th April 2004, 01:31 PM   #2
and this
Old 5th April 2004, 01:32 PM   #3
Old 5th April 2004, 01:48 PM   #4
karma is offline karma  Canada
karma's Avatar
Default .
for me i replace caps. and recheck solder joints replace power resisters where needed. i would need it in front of me to find the problem
i get allote of old amps that work but dont have the power thay
had so replaceing old caps help thay dry out
Old 5th April 2004, 11:50 PM   #5
ok thanks karma i'll give replacing the caps a go
Old 6th April 2004, 12:15 AM   #6
slowhands is offline slowhands  United States
slowhands's Avatar
Those weren't half bad amps. I suspect you have a damaged input pair transistor, probably from being overdriven (I WANT IT LOUDER!!). Second guess is a weakened output transistor, or damaged Vbe multiplier transistor. Given that is still plays, that sort of points to the input pair, weak and giving extra offset so the relay is intermittent on closing.
It's nearly impossible to diagnose this with the little information you suggested, but I've repaired a few of these and that's my hunch. You really need a scope or at least a DVM to work on these. Maybe it's time to take it to a tech??
Old 6th April 2004, 08:00 AM   #7
yeah, it probably was from being overdriven, i however do not think that getting a tech onto it would be worthwhile, as that would probably cost more than the amp is worth itself. I tried the local electronic stores today for the caps and they only had a few of them, which seemed useless, anyone know a good place in sydney to get a wide range of caps? Is it possible to use bigger caps to give more headroom?
Old 6th April 2004, 08:01 AM   #8
also slowhands are those transistors easy to come by? i'm thimking about just replacing the lot
Old 8th April 2004, 07:01 AM   #9
right, all the caps have been replaced and the sound is noticeably better, i'm thinking of replacing the transistors with more powerful one's, or do i have to match what i've already got. any help MUCH APPRECIATED
Old 8th April 2004, 07:15 AM   #10
slowhands's Avatar
I don't recommend wholesale replacement of all transistors. You can do a lot of damage to the board when you desolder, and they don't wear out. Just the outputs and input pair seem to take a beating and fail, in my experience. Fix what's broken, leave the rest alone. Is your crackling sound gone? If so, let it be...
Some Japanese transistors have a different pinout than the common USA transistors, so you have to check the pinout of any device you remove and put the same type in. There are literally thousands of part types, so no universal crosses can be listed.
To do this right, you need to get the service manual if you are not able to wing it based on experience.
old Pioneer sa-5300Hide this!Advertise here!
Logitech Z-5300 without remote orexio Chip Amps 29 16th February 2017 11:42 PM
z-5300 sub pins superxpro12 Subwoofers 4 20th April 2015 05:33 PM
Logitec Z-5300 problems BLARGAG!!! Subwoofers 7 7th August 2009 11:02 AM
FS:Adcom GFA 555 and GFA 5300 trusound Swap Meet 0 13th December 2005 05:06 PM
Copyright ©1999-2017 diyAudio
