Old 5th April 2004, 01:21 PM   #1
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Default Help please for opamp challenged..........
What I've got is a stereo amp which I'm using as a sub power amp. The tone control section and preamp was was removed as it was faulty. I've added a sub bass processor which provides gain, low pass filter, equaliser, 20Hz filter and inverter/buffer output.
The circuit diagram is for the buffer/gain stage (LM833) which gives ±12dB or a gain of 4/0.25 via a pot RV1 (varies the input attenuation at R4 and the opamp's negative feedback at R6). The circuit is balanced, gain of 1, with RV1 in the centre position. What I want to do is increase the gain to 8/0.125 to give me ±24dB as when the preamp was removed, a lot of gain was lost.
Being opamp challenged, I think it's just a matter of:
increasing R4 and R6 to 100k?
or decreasing R3 to 51k?
or decreasing R5 to 7K5?
or am I way off course?
What would be the maximum gain that could be used?
Any advice would be appreciated.
Old 6th April 2004, 01:08 PM   #2
rabbitz's Avatar
Unhappy What? No replies......
In the too hard basket, hey.
I've had my books out and can't figure out how they get a gain of 4/0.25 with this circuit.
Old 6th April 2004, 02:07 PM   #3
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
decreasing R5 to 7K5 will give you 8/0.125 or ±18dB
Old 6th April 2004, 02:42 PM   #4
rabbitz's Avatar
Talking Thanks
Excellent, thanks very much.
Customizing manufactured speakers to fit a height challenged AV theatre setup. morkyz Multi-Way 8 12th January 2009 04:09 AM
CF-Opamp Onvinyl Parts 6 3rd April 2006 03:09 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
Page generated in 0.08396 seconds (64.67% PHP - 35.33% MySQL) with 11 queries
