#21 |
Typical input bias current of 2pA, input voltage range extends below ground for single-supply operation, designed for true single-supply operation, but works fine on split supplies, and no phase reversal for voltages exceeding V+ or V- (as long as a resistor is in series with the input pin.)
Just seems taylor-made for the job at hand, and I've used it as a servo chip in several amps. I've never seen offset larger than about 0.3mV with this opamp used. |
#22 |
I've got a Parasound 1500A, which is working fine..but..I'm curious if overal sonic qualities will improve with a different op amp (DC servo loop).
I've upgraded the PS quality around the AD711, but I've no idea if this improved the sound quality or not. I don't think I'll ever seriously use the amp for it's sonic qualities. Amps with DC servos of that nature aren't high on my list of 'amps worth listening to'. ie, right down there with the Brystons and the like. Oops. Jim might read this, or evern worse..Stu. Brystons are great!! The amp (while in my posession) is just for buying broken..and selling fixed, which I'm in the middle of doing. Amp is in perfect shape, now I need to do a bit of 'sonic rescue' to the amp, simply because it is in my posession - and it looks like it needs it. I'd hate to be caught selling someone a stock item......
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#23 | |
As for Mouser, you can find new stuff by going to (for example) Fairchild's website and searching for new parts in the area you are looking for, copy and paste the part # on the mouser site. It may show up as page 9999 of the catalog, but not IN the catalog. Although most new parts Fairchild allows samples to be ordered. BTW, just a point of interest, Mouser has a couple new Fairchild mosfets(not exactly complements ): http://www.fairchildsemi.com/ds/FQ%2FFQA36P15.pdfhttp://www.fairchildsemi.com/ds/FQ/FQA70N15.pdf Pretty hefty SOA
All the trouble I've ever been in started out as fun...... |
#24 |
I thought LM411 was OK for DCservo duty, but the last mention was way back at post8. What part of the spec makes 411 unsuitable for servo? What improvements (specifications and realisability) are the newer ICs bringing to the table?
regards Andrew T. |
| Servo add-on PCB | Nicks | Chip Amps | 3 | 21st February 2006 05:36 AM |
| Has anyone tried servo-less BPA 200? | goldyrathore | Chip Amps | 5 | 3rd April 2005 07:10 PM |
| To servo or not to Servo.. | ReSiStAnCe | Chip Amps | 10 | 7th February 2004 01:06 AM |
| DC servo | Bensen | Solid State | 0 | 23rd May 2003 11:34 AM |
| Page generated in 0.08545 seconds (67.23% PHP - 32.77% MySQL) with 10 queries |
