Old 4th April 2004, 07:15 PM   #1
Kal is offline Kal  Germany
Default JOB circuit by GOLDMUND
Hello,
I recently read a review of a power amp by GOLDMUND that uses the JOB-circuit. This amp seems to be breathtakenly fast... and great sounding!!!
And it is only made with a very few parts...
Has anyone more information about the JOB-schematic/circuit except for what is available at www.goldmund.com or www.jobsys.com?
Thanx
Old 4th April 2004, 07:34 PM   #2
lgreen is offline lgreen  United States
lgreen's Avatar
Default Good Question
I asked the same thing awhile ago, see my earlier thread:
http://www.diyaudio.com/forums/showt...965#post189965
I'm with you, I'd like to make one of these if provided with the right information on what's in there.
Old 5th April 2004, 05:37 AM   #3
difficult to copy
it contains a double sided pcb with lots of smd transistors
no markings on the transistors also
Old 5th April 2004, 09:26 AM   #4
subwo1 is offline subwo1  United States
subwo1's Avatar
Default double current mirrors
So far, the fastest topology I have found is current mirrors connected to the collectors of dual input pairs. They provide active base pull-down for the upper and lower VAS transistors. I wonder if that topology is what they use. Simulations I have done indicate a slew rate up to 200uV/s when used with complementary source follower mosfets. In the simulation, output device idle current was set at 500ma. Maybe these ideas will give you some guidance.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 5th April 2004, 10:09 AM   #5
Banned
Send a message via Yahoo to Elso Kwak
Cool Re: double current mirrors
Hi, I would replace the VAS transistors by Darlington connected transistors. The current mirror likes to see a high impedance as load.
Old 5th April 2004, 10:54 AM   #6
subwo1's Avatar
Hi Elso, it would just happen that we end up with such a trade-off. The fast, active pull-down of the current mirror likes the high impedance of a Darlington pair with slow response. But then several resistors would be needed to make up for the forgone self-biasing nature of the current mirror. Maybe lets just make that waif of a current mirror sweat and drive that single transistor.
USMPS
Old 5th April 2004, 01:41 PM   #7
Subwo1, try simulating the circuit with the Hitachi lateral MOSFETs as output devices. These are what are used in the Goldmund. Their lower input capacitance may speed things up even more.
Also, you could try adding separate emitter followers between the current mirrors and the VAS. I think this is what Elso meant, and it should also speed things up.
Old 5th April 2004, 01:57 PM   #8
Banned
Arrow Darlington
Hi Charles,
No I meant something like the VAS stage as here:
http://home.kimo.com.tw/skychutw/ampzilla/index.html
Unfortunately the AmpzillaII schematic is gone but here is a detail.
Old 5th April 2004, 02:18 PM   #9
I think the Ampzilla circuit is a variation on what Borbely called the "Lender circuit", where the emitter of the VAS is driven by one phase of the diff pair, while the other phase drives the base of the VAS. I can't see where the collector of what looks like an emitter follower is connected.
At any rate, adding an emitter follower to drive the base of the VAS will eliminate the slowdown from the Miller capacitance of the VAS. This is what I think we were both suggesting to Subwo1. However, I don't think it is possible to combine the "Lender circuit" with the current mirror.
Old 5th April 2004, 05:02 PM   #10
Hi Charles,
I really like our amps, too!!! One of the best amps I ever heard!
But unfortunately I can not afford them at the moment...
I really would like to have your AX-7 in a unbalanced version(only RCA inputs).
For some reason I prefer unbalanced interconnects...
Anybody know about goldmund DAC Mimesis 20 series AD1865 Digital Source 5 22nd February 2009 03:13 AM
Goldmund lumanauw Solid State 32 26th January 2006 04:08 PM
Goldmund DC offset readjust ? ad010685 Solid State 7 29th December 2005 09:26 AM
Goldmund Mimesis 7.5 pre - Good ? ad010685 Solid State 3 12th May 2003 03:28 PM
Goldmund Speakers audioPT Multi-Way 0 11th September 2002 09:52 AM
Page generated in 0.10558 seconds (81.08% PHP - 18.92% MySQL) with 11 queries
