cyrus 1 output transistor question. push-pull?
Old 31st December 2017, 10:36 AM   #221
randombeliefs is offline randombeliefs  United Kingdom
Originally Posted by Mooly View Post
Sounds like a plan
keep waiting for the catch ... but so far so good. I've just left the presets in with blobs of nail varnish to stop em moving
Old 31st December 2017, 11:05 AM   #222
R.I.P.
the sealed presets are usually for the bias setting.
But the Cyrus has fixed resistor bias.
Are they for output offset?
regards Andrew T.
Old 31st December 2017, 11:08 AM   #223
Mooly's Avatar
Well hopefully there isn't one
(When you fit the new fuses, make sure the fuse holders are reasonably tight)
Old 31st December 2017, 11:10 AM   #224
Mooly's Avatar
We modified the amp to adjustable bias to cover the possibility that the replacement transistors might be different in terms of turn on voltage. It does happen with older stuff as semiconductor doping processes might have changed.
Old 31st December 2017, 11:38 AM   #225
I added the presets across the solder posts next to R81 after removing R81
I expect mission provided the posts fir service convenience ?
Old 31st December 2017, 11:42 AM   #226
Ice just swapped out the old 470uF caps on the preamp psu side for nichicon finr gold 100v jobs. Panasonics I wanted to git are a bit too big. And putting fine golds in where the 22uF polarised caps are on the preamp side. Have nichicon muse forcthe bipolars
Old 31st December 2017, 01:28 PM   #227
Mooly's Avatar
Looks like you are having fun Just be careful
Old 31st December 2017, 01:39 PM   #228
yeah it's like the victory lap now. hope i don't fall on my face
Old 3rd January 2018, 01:26 PM   #229
Default How it going ?
Originally Posted by cardiffborn View Post
Hi.
Recently I let someone borrow my Cyrus 1 for a charity event and unfortunately it returned as a dead Cyrus. I did a visual check and replaced a 3.15A fuse, only to discover that one of the output transistors was shorted. Trying to find a replacement has lead me to some interesting sites, without much luck. Then I found this thread and have been amazed by the help being given to someone who wants to learn by doing. I'm an advocate of learning by failing, though I don't actually see it as failure.
I've registered and read all the posts and am about to put together my own shopping list. I just wanted to say 'thanks' to all who have been helping because it's going to help me no end. Also, it's a change to read comments that actually inform and share, rather than recommend that one finds an expert to do it for you.
My Cyrus 1 got fixed by this thread and the brilliant help within it.
How are you getting on with yours ?
Old 4th January 2018, 10:56 AM   #230
cardiffborn is offline cardiffborn  Wales
Default Cyrus 1 might get back on the road again
Hi and thanks for asking about my Cyrus 1. I have to admit that I have been following this thread until the final chapter before I jump in myself. OK, I could blame the Christmas festivities but that's not true. The thread reads like a crime novel and fortunately has a happy ending. I've made notes from all the posts and will be ordering some goodies from Farnell soon. I have also unearthed my old Sinclair meter to complement my other cheapie meter. All I need to do now is tidy the shed, cut the grass, paint the house and then jump in with both feet.
The support you have been given is amazing, and my faith in humanity somewhat restored by those prepared to offer assistance patiently and without recourse to bitchy comments. I may not be as speedy as you but I reckon that with all this info I should be able to do something.
Actually, I am going to build a bulb tester first seeing as many posts indicate its importance.....
Watch this space, but don't hold your breath. Have a great 2018
cyrus 1 output transistor question. push-pull?Hide this!Advertise here!
6l6 push pull output question(s) Bas van Dijk Tubes / Valves 26 30th September 2017 09:00 PM
General Class D push pull amp output question Chris Wilson Class D 11 24th April 2017 12:44 PM
Push-Pull fixed bias and output power question LATUBEGEEK Instruments and Amps 30 27th February 2015 02:55 PM
Question: Acceptable DC current in push-pull output transformer due to tube mismatch? EWong Tubes / Valves 44 30th April 2014 11:08 PM
Push Pull Output Stage Question 316a Tubes / Valves 4 10th February 2003 01:04 AM
