cyrus 1 output transistor question. push-pull?
Old 9th December 2017, 07:06 PM   #11
randombeliefs is offline randombeliefs  United Kingdom
Originally Posted by Mooly View Post
There are a couple of variations of this amplifier in the service manual although both are basically the same configuration details.
You need to be confident in fitting replacement transistors, probably of a different type to the original parts. Also as a general rule, avoid buying semiconductors from well known auction sites, there are just far to many fakes and remarked devices around.
thanks for the tip
i was looking at maplin Farnell and RS components.
can transistors just fail due to age or is there likely to be another underlying cause and the transistors failed as a consequence?
Old 9th December 2017, 07:12 PM   #12
Mooly's Avatar
Hmmm... transistors don't wear out as such, and don't age as such but it is a fact that certain devices of a certain age (and from certain manufacturers) do suffer problems and unusual failure modes. There are no hard and fast rules on that, but I found as a service tech you did get a second sense when faced with these things.
RS, Farnell and CPC are probably the best suppliers in the UK as a generalisation. CPC is part of Farnell.
Old 9th December 2017, 07:30 PM   #13
Originally Posted by rayma View Post
Many amplifiers are "quasi-complementary", using all the same output device for both polarities.
This amp uses all identical outputs, with paralleled pairs for each polarity for each channel.
There's probably more wrong than just those, like the emitter resistors and driver transistors.
Cyrus 2 - Manual - Stereo Integrated Amplifier - HiFi Engine
thank you
Old 9th December 2017, 07:33 PM   #14
what's would cause it to go wrong if not a transistor failure do other bits die of old age ?
Old 9th December 2017, 07:47 PM   #15
ohdsp is offline ohdsp
If you need output transistors for a Cyrus one I am running *13009 devices in several Cyrus One's; STW13009 (obsolete) in a TOG model and FJP13009 in a Issue 06. The FJP13009 are dead cheap and better ratings. FJA13009 may work in TOG models as "uprated" devices.
Check out the Open Hardware DSP Platform:
http://www.ohdsp.org - http://github.com/ohdsp
Old 9th December 2017, 07:49 PM   #16
amptech is offline amptech  Scotland
Send a message via MSN to amptech
Originally Posted by randombeliefs View Post
thanks very much. i am trying to learn but it's hard to know where to start and at what point you know enough to have a go
Hello there,
Most of us here have been in the service trade for many a year and getting started on such topics can cost a high price if things go wrong plus you get zapped along the way!
Basic ohms law help's with working out volts current and resistances. Followed by test equipment use, meters for checking and how to carry out live testing.
Try a small chip amplifier ie tda2030 this gives 10 to 18 watts and very easy to build.
There are plenty of audio file books or even on line info and remember electrical saftey at all times.
Good luck with things
Old 9th December 2017, 07:54 PM   #17
i think it's issue 07. it has the cast heatsink integral to the base and the balance control but no toggle switch yet.
Old 9th December 2017, 08:02 PM   #18
would BUV48A work ? can't seem to find 13009.
Old 9th December 2017, 08:04 PM   #19
Originally Posted by amptech View Post
Hello there,
I would prefer he send it to ARS for a full service personally, but he can't afford to. Basically if i can't fix it she just has to do without. Which is looking likely ! reading up as best I can ...
Old 9th December 2017, 08:06 PM   #20
I believe the Cyrus PT7 (Cyrus One and early Two) is the BUV28 and the PT77 (later Cyrus Two) are BUV48.
If the BUV48 fits your version it will work; even if the device is bigger than the original.
cyrus 1 output transistor question. push-pull?Hide this!Advertise here!
6l6 push pull output question(s) Bas van Dijk Tubes / Valves 26 30th September 2017 09:00 PM
General Class D push pull amp output question Chris Wilson Class D 11 24th April 2017 12:44 PM
Push-Pull fixed bias and output power question LATUBEGEEK Instruments and Amps 30 27th February 2015 02:55 PM
Question: Acceptable DC current in push-pull output transformer due to tube mismatch? EWong Tubes / Valves 44 30th April 2014 11:08 PM
Push Pull Output Stage Question 316a Tubes / Valves 4 10th February 2003 01:04 AM
