Cascading diamond buffers - a cheap low THD 10W amp with TIP41C
Old 15th May 2018, 01:48 PM   #281
anatech is offline anatech  Canada
anatech's Avatar
Hi Semola,
I'm sorry you felt I was aggressive, but I was merely matching what I perceived was the tone of your post. The views I felt were those of someone who reads the popular press in audiophile land and were unwarranted. It seemed like you made your mind up without any understanding of the circuit that was presented.
Had you posed your comments as questions, you would have received an explanation instead of what I posted. Keep in mind that whatever you post will be read by people who are experts in the field, and also others like yourself who have other expertise but not in audio design. We don't want to further myths, but rather have an opportunity to learn.
One reason these "Diamond buffer" circuits are popular is that they are blazingly fast while also having low distortion. The signal is distorted by the first transistor stage as is normal, while the output stage in the diamond distorts it in a complementary way, which tends to undo the distortion caused by the input stage. The actual diamond formation consists of only four transistors in the audio path.
There are diamond buffers produced as an IC in one package, and have been for years. The BUF634 is one good example of this. To gain some understanding, why not look up this part's data sheet? You will see the actual diamond buffer along with some support circuitry. But by reading the specs you will gain some insight into the capabilities of this design.
-Chris
"Just because you can, doesn't mean you should" my Wife
Cascading diamond buffers - a cheap low THD 10W amp with TIP41CHide this!Advertise here!
Questions regarding diamond buffers. horizonrays Solid State 21 19th November 2017 11:36 AM
HDAM / Diamond Buffers Q RnR Solid State 0 21st April 2009 09:59 PM
A question about diamond buffers darian Solid State 41 3rd July 2008 01:20 AM
A question about diamond buffers darian Analog Line Level 3 24th June 2008 07:38 PM
Diamond buffers Nordic Parts 7 13th March 2007 02:13 PM
Resources saved on this page: MySQL 70.00% / PHP 32.94%
