Cable related hum
Cable related hum
Old 23rd May 2005, 03:00 PM   #21
anatech is offline anatech  Canada
anatech's Avatar
Cable related hum
Hi Harry,
I was talking about any audio or TV tuners. I really do not care what happens to the cable box. You need to break the ground before it hits the first piece of equipment. A 1:1 transformer from a good vendor is the only reasonable way to do this. The cable company may be able to supply this and boost your signal accordingly. Then they are responsible for the quality of signal. It may cost you some money but is worth it.
The hum comes from multiple grounds. Circulating ground currents cause the hum. The earth is used as a return for your electrical power grid and gives rise to potential differentials between ground points. Complete with any waveform distortion. The cable is providing another path for these currents.
-Chris
Old 23rd May 2005, 03:08 PM   #22
h_andree is offline h_andree  United States
I'm currently thinking about using the Creative Labs
DDTS-100 decoder. That will allow me to use the
digital out. Then I can break the ground loop on
the digital audio cable (If necessary).
It will also allow me to use surround sound. I think
the audio DAC in the cable box do not sound very
good anyway.
Harry
Old 23rd May 2005, 03:10 PM   #23
anatech's Avatar
Cable related hum
Hi Harry,
Now that is likely true. I would follow the ground breaker lead in any case. You have a valid reason to use the outboard DAC.
-Chris
Old 24th May 2005, 03:43 AM   #24
amplifierguru is offline amplifierguru
Account Disabled
I always use the safety ground because it's good to reference your system to - for safety! My kids are worth it. I do it through a 10 ohm resistor with eachway diodes in parallel. No ground loops.
Old 24th May 2005, 04:44 PM   #25
I checked my second box. It has an optical digital out.
If I use that with the new decoder I've I will isolate my audio equipment from the cable box.
This way I do not have to float my amps. I'm building a new
set of amps (3-4 month time frame). I will consider putting the
diode protection in.
Harry
Old 28th May 2005, 02:46 PM   #26
I got the processor. However the box that has the optical
out does not perform as well. It gives occasionally a
high frequncy pop when sh\witching channels. It also
forces my TV to switch input formats. This takes a while
(1-2sc) and is annoying when flipping channels). The digital
input is connected to ground and hums.
So I'm back to floating the power amps. Although they have
been working fine for 7 years I'm still not so happy as they
do have 750V power inside.
Harry
Old 29th May 2005, 01:48 AM   #27
anatech's Avatar
Cable related hum
Hi Harry,
Float the cable ground!!!!
However you choose to do it.
-Chris
Cable related humHide this!Advertise here!
Anyone using microphone cable in making their phono cable? rich121 Analog Line Level 8 10th September 2010 01:50 AM
cheap cat5e cable for speaker cable fishline Full Range 6 19th May 2009 08:42 PM
DAC-related reading anli Digital Source 0 26th February 2009 09:17 AM
New in package Component Video Cable and Toslink Cable for sale cheap jainbaby Swap Meet 1 30th December 2007 06:18 PM
problems with speaker cable as power cable pjpoes Parts 11 14th January 2007 09:24 PM
