Cable related hum
Cable related hum
Old 22nd May 2005, 02:07 PM   #11
djk is offline djk
R.I.P
djk's Avatar
http://www.partsexpress.com/pe/showd...number=180-075
Old 22nd May 2005, 02:47 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
Cable related hum
Hi K-amps,
As you have proved empirically, the hum DOES come from the cable ground, which is the worlds largest ground loop. Use 1:1 balun transformers to isolate the cable ground. The better quality ones have lower losses. I had to service all kinds of gear due to ground tracks being blown ... to the video jacks. Hmmmm, not warranty.
The largest amount of destruction I have ever witnessed in a lightning strike occurs every single time when cable is involved. I will not have cable in my house for that reason. Do use the three wire grounded outlets.
-Chris
Old 22nd May 2005, 03:05 PM   #13
SM2GXN is offline SM2GXN  Sweden
Send a message via ICQ to SM2GXN
http://www.partsexpress.com/pe/show...tnumber=180-075
That's the way to go, this is nothing more than 2 coupling caps 10nF, one for the center conductor and the other screen.
It's wise to not only break up the screen of the coax because even the center conductor is grounded through the input circuit of the rf amp in the tuner. I can't come up with any reason why this could attenuate the rf.
This is a very common problem, hum on audio hum bars on tv caused by a groundloop.
I agree with John10
I think K-Amps hum problem may be caused by a ground loop created by the ground difference between house wiring ground and the cable system ground.
Björn
Old 22nd May 2005, 03:07 PM   #14
Burnedfingers is offline Burnedfingers  United States
As Chris and DJK have pointed out the problem of hum is caused by the cable coax. This problem is eliminated by the usage of an issolation transformer such as the one DJK has left a link to.
Old 22nd May 2005, 03:25 PM   #15
anatech's Avatar
Cable related hum
Hi SM2GXN,
The ones I use are 1:1 RF transformers. Complete isolation. Better brands will offer very low losses. I haven't seen the capacitor types in a long time. Same thing goes for splitters and attenuator taps. Use good stuff or the quality really goes down.
-Chris
Old 22nd May 2005, 05:25 PM   #16
h_andree is offline h_andree  United States
I used the partsexpress isolator. This one attenuates the
signal. I get breakup of my digital cable signal. HBO
does not show at all.
I'm trying to use caps in the shielding side only. What kind of caps
would you use (Ceramic disk? Film?).
Harry
Old 22nd May 2005, 07:07 PM   #17
Hi Chris!
I agree, if you by it's better to stay with better brands. A good 1:1 RF transformer shouldn't be lossy.
Anyway the signal at the tv jack is usually between 60-80dbmV so
a couple of db loss will do no harm as long as it doesn't go much below 60dbmV.
I use ceramic disc caps they will do the job.
Bjorn
Old 22nd May 2005, 08:03 PM   #18
It's very sensitive. I just tried a single cap on the shielding.
It does get rid of the noise but also of the signla for some
channels. Again some of the premium channels drop.
I'm considering using the digital audio out. Are there cheap
decoders for sale?
Harry
Old 22nd May 2005, 09:09 PM   #19
anatech's Avatar
Cable related hum
Hi Harry,
You need to totally isolate the signal or you may toast some tuners. There may be a DC path due to an RF input transformer or coil. Any gear between the cable ground and local earth ground is at risk of being totally blasted. Just depends on the ground differential of the next lighting strike.
-Chris
Old 23rd May 2005, 12:22 PM   #20
The tuner is property of the cable company. Of course
the signal can go through my pre amp.
Luckely we are in New York City. Lightning is not frequent
and there are many high buildings around. I think the
problem stems from insufficient grounding. The cable
comes from the roof and services many apartment
buildings. The installation is done pretty poorly.
As a follow up: I did try to ground it by connecting it
to the outside of my metal electrical duckts. That
reduced the hum somewhat but when I listened to the
DVD the hum was there. I disconnected the cable box but
the hum remained. It's able to send the hum through the
ground to the stereo.
Everthing I try to do gives a poorer image quality. I'm wondering
if I have a marginal cable signal? I wonder how I can
verify that? Upstairs strangely enough I do not have a hum.
They are connected through a different cable run. I also have
different gear (I'm using a Maranz HT receiver). Downstairs
I'm using my own pre-amp and Cary tube gear.
I'm wondering if it's possible to buy a cheap DVD player and
modify it so it can work as a Dolby decoder? Then I can put
a filter on the ground of the digital input and I would have clean
sound. If we get a power surge it would only blow the cable
box and maybe the filter.
Harry
Cable related humHide this!Advertise here!
Anyone using microphone cable in making their phono cable? rich121 Analog Line Level 8 10th September 2010 12:50 AM
cheap cat5e cable for speaker cable fishline Full Range 6 19th May 2009 07:42 PM
DAC-related reading anli Digital Source 0 26th February 2009 08:17 AM
New in package Component Video Cable and Toslink Cable for sale cheap jainbaby Swap Meet 1 30th December 2007 05:18 PM
problems with speaker cable as power cable pjpoes Parts 11 14th January 2007 08:24 PM
