Hybrid tube front end and transistor output stage
Old 4th April 2004, 02:10 PM   #1
Burnedfingers is offline Burnedfingers  United States
Default Hybrid tube front end and transistor output stage
Hi
Any ideas on how to construct a transistor output stage with a minimum amount of parts and couple to a tube line stage or tube front end. I have found several Mosfet hybrid designs but I want to stay with TO-3 outputs like the Motorola MJ15024 and MJ15025.
Joe
Old 4th April 2004, 04:08 PM   #2
Pjotr is offline Pjotr
Pjotr's Avatar
Default Re: Hybrid tube front end and transistor output stage
Why?
I would go for something like a choke loaded source follower driven by a Mu stage if you donít need lots of power. That is for sure a minimum of parts
Cheers
Old 4th April 2004, 04:22 PM   #3
grataku is offline grataku  United States
Have you seen this?
http://www.audiodesignguide.com/ba/gy50sh.jpg
Old 4th April 2004, 07:25 PM   #4
Why?
To be honest I like transistors better and I like to use what I have on hand. No offense.
Pjotr
Thanks for the link. It looks like a triple darlington output stage but its kinda blurred and I can't see it all that well.
Joe
Old 5th April 2004, 12:00 AM   #5
djk is offline djk
djk's Avatar
'burnedfingers'
Hi Joe!
You will probably have to run a tripple with the MJ15024/25, unless you're driving it with a cathode follower like a Foreplay.
If you want to get fancy you could reverse the driver transistors so the tripple looks like the one in an Altec 9440A, McIntosh 2120, Ampzilla III, etc. This would cut down on the bias a bit too.
If you really slam a 6C45Pi at 30mA with a choke load you could do a double with the MJE15030/31 and MJ21193/94.
What were you thinking about for the front end?
Old 5th April 2004, 12:17 AM   #6
Hi Dennis
I will see if I can post this line stage.
Old 5th April 2004, 12:28 AM   #7
The power supply I actually used is different than this one. Since I don't have the ability to build a schematic and post it this is as close as I can get. My B+ is higher and the plate resistor is larger but bias is the same as this one.
Joe
Hybrid tube front end and transistor output stageHide this!Advertise here!
HK 'Deuce front end on G2 drive output stage? GordonW Tubes / Valves 0 9th June 2008 03:22 PM
Elektor op-amp front-end with mosfet CF output stage Dusk Elektor 1 5th April 2006 05:09 AM
New Hybrid Output Stage and booster for SE Amp smoking-amp Tubes / Valves 3 20th March 2006 03:24 AM
Hybrid amp -> tube for VAS stage rtarbell Tubes / Valves 3 26th November 2005 10:13 PM
TV Horzontal Output Transistor for output stage..? ronybc Solid State 46 10th October 2005 03:26 AM
Copyright ©1999-2017 diyAudio
