One of the Top Solid-State CFA amp design
Old 16th July 2018, 06:26 PM   #811
AndriyOL is offline AndriyOL  Ukraine
Do you mean external series resistor 1R at output or input? And 8R dummy load with 47nF in parallel?
Perhaps better would be to perform these tests with new optimized pcb? Do you think the schematic is complete for new layout? The doubts left only in compensation values.
If for pristine and pure adoration - it's diyAudio dedication!
Old 16th July 2018, 07:34 PM   #812
mjona is offline mjona  New Zealand
External series resistor at the output and 8R in parallel with 47nF. You should try first a 50kHz square wave into the 8R dummy load alone with the amplifier as it stands with a range of low level input signals.
Old 17th July 2018, 10:52 PM   #813
I've made a layout for this sim file. I added 10R GND resistor as per original schematic. There are two gnd planes, at IPS section and as output zone. One thing I'm not sure with gnd planes, as this is not visible in the layout, is how opposite layer components go through these gnd planes.
Comments and offers are welcomed.
Old Yesterday, 01:17 AM   #814
Douglas Self made repeated comments earlier that a ground plane is not necessary.
Old Yesterday, 04:56 AM   #815
kct is offline kct  Canada
kct's Avatar
Sadly, Douglas is very mistaken in his believe.
Old Yesterday, 05:59 AM   #816
I may believe that it can be true, but using gnd plane turns out with much compact and easier layout than if I route gnd tracks separately. It's beneficial in two points: simplicity and noise immunity.
In fact Douglas agreed as well gnd plane can be beneficial in post 115, as I understood.
Sorry, previous image was without GND plane, I thought I uploaded the correct one. Chris, please replace the image with this one. Thanks.
Old Yesterday, 07:23 AM   #817
udok is offline udok  Austria
Do you ever sleep :-)
Old Yesterday, 07:30 AM   #818
Of course)
One of the Top Solid-State CFA amp designHide this!Advertise here!
Tubelab Solid State OPT design hellokitty123 Tubelab 3 30th December 2017 12:35 PM
How to design solid state amplifiers. rutager Chip Amps 10 19th January 2017 12:41 PM
Best books for solid state design? Bitrex Solid State 26 8th March 2015 11:13 AM
25 WPC stereo amp design, help? (Solid state) cmjohnson Solid State 21 17th April 2011 10:25 PM
Started to design solid state amp + calculations Bensen Solid State 11 22nd May 2005 03:55 AM
