Dont know if this question makes sense. But if I ask about specific examples it might be clearer.
Is length of wire from output transistors to speaker terminals on the back of the amp important ? Is wiring length from chassis mounted volume pot to pcb ? Or from the RCA input to the PCB/pot ? what about within the circuit ? Gainclone fans go to a lot of trouble to put the power supply caps right next to the chip. Does this apply to non chip amps ? what about the length of ground wires/pathways? Any explanations ? Thanks |
#2 |
the gainclone has got the caps so near for decoupling purposes as the main chip itself is essentially a very powerful opamp...as for "normal" amps it is not so critical...but if the power supply is located quite a distance...sometimes some caps are needed on the board itself...if u know wad i mean...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#3 |
The short answer is that you should always make wiring as short as possible. If you have to make some runs longer, you must look into specifics of the amp design.
Depending on the amp, in some areas it can be critical. The reason GainClones are the way they are is the minimalist approach - super short feedback path to avoid extra components there to guarantee stability. Do you have a specific amp design in mind?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 | |
some of my ideas ( i dont know if they are right) include: from output transistors to speaker terminals on the amp should not matter since theres going to be a length of loudspeaker cable. The portion of wiring within the amp represents only a small portion of the total length. Ive read somewhere ,and cant find the reference now that emphasised making the connections from volume pot and pcb ultra short if possible mounting the pot onto the pcb but why I dont know. Indeed elliott sells pot extension shafts to achieve this. If the tracks on a pcb are so close together can you not get unintended EMF going from one track to another ? |
#5 | |||
#6 | |
The worst case of using wires would be from pcb to output devices. Had one B&O receiver that did just that and it was on the edge of stability. Do not run signal input and output wires together and as a rule of thumb keep every connection as short as possible (just enough to accomodate enclosure placement) and for power supply /star ground/ and speaker out use the thickest wire possible (14ga will suffice) and solder when possible rather than using crimped connections. Keep all returns to star ground the same length though... |
| important question please help me | odysseybmx414 | Chip Amps | 3 | 8th May 2005 11:24 PM |
| An Important Read | valveitude | Tubes / Valves | 5 | 29th April 2005 02:11 PM |
| Important!!! | Clarkcr | The Lounge | 4 | 15th September 2004 04:34 AM |
| Bl important? | pkgum | Multi-Way | 2 | 1st January 2002 05:07 PM |
| Page generated in 0.09858 seconds (76.54% PHP - 23.46% MySQL) with 10 queries |
