ASTX SA2014 Build Thread. 2 x 400W@4R with CNC machined case.
Old 19th December 2017, 08:30 AM   #11
astx is offline astx  Austria
Very clean soldering!
One hint: first solder flat parts and last solder the highest parts.
Matching: I have matched them out of the whole batch for lowest Vbe and hFe difference. During matching with your DCA 75 pro all transistors should have the same temperature. e.g. Use a thick aluminium brick and let the transistor cool down after you have touched them. After measurement write down the number on the back side of the transistor so you can find the part after sorting your spread sheet.
Have fun, Toni
Hint: have a look at first post of my threads for an updated index!
Old 20th December 2017, 08:19 AM   #12
Of course it would be very hard to write down a number on the small signal transistors...
I have used this little boxes to sort them by number.
You simply "scan" your sorted excel sheet for pairs and select them by number from the box.
Old 9th February 2018, 08:20 AM   #13
Dear Mark,
any update? Any help needed?
BR, Toni
ASTX SA2014 Build Thread. 2 x 400W@4R with CNC machined case.Hide this!Advertise here!
WNT: astx pcb set for SA2014 rev 3.4.2 :) Turbon Swap Meet 0 20th July 2015 07:47 PM
The curious case of the edited thread.. ScottG Everything Else 12 25th October 2011 11:46 AM
Build your own case Steve Dunlap Construction Tips 92 30th March 2010 12:08 AM
warez the cheap amp case thread :) karma Chip Amps 12 24th January 2005 09:04 PM
