Hafler xl-280 pop on startup and higher DC offset o
Old 13th November 2017, 07:12 PM   #1
rory957 is offline rory957
Default Hafler xl-280 pop on startup and higher DC offset o
Hi,I need help.
I bought Hafler xl-280 with damaged both channels.
Left channel repaired with replacing output FET-s with BUZ900-BUZ905 and it works fine with bias 300 mA and DC offset 0,01 V. On left channel I replaced output FET-s with BUZ900, BUZ905 and Q9, Q10, Q14 and Q15.Problem is pop during startup. Can not regulate bias lower then 320 mA and DC offset is about 0,15 V. Thanks.
Old 14th November 2017, 04:54 PM   #2
trebolo is offline trebolo  United States
I would check the input fets. And you may have a oscilation causing the dc offset and making the bias adj difficult. What did you replace transistors with
Old 14th November 2017, 08:32 PM   #3
I did not check input's FET-s. I bought transistors from: HAFLER XL-280 XL-600 PC-40 REPAIR KIT | eBay and replaced Q9 with 2N5550, Q10with 2N5401, Q14 with 2N3440 and Q15 with 2N5416. Testing amp with 10 % lower mains voltage passed with same pop on speakers, lower bias and almost same DC offset. I"ll check FET-s on input. Thanks for help.
Old 14th November 2017, 09:49 PM   #4
MAAC0 is offline MAAC0  Portugal
Transistors from ebay... Are they genuine parts ?
Old 15th November 2017, 03:45 AM   #5
Do you have a Scope? TO look for oscillation. C11 is a variable 120pf cap. If you could adjust a little it may help to adjust bias current, maybe get a second opinion on it first
Old 15th November 2017, 04:23 AM   #6
msb64 is offline msb64  Canada
That eBay seller is qua-co ( Ed Fantasia ), a former tech for Dynaco and project engineer for Hafler back in the day, he really knows his stuff and sells quality components.
I have purchased items from him before, from components to upgrade boards, and he was always helpful in response to my questions.
It wouldn't hurt to ask him about your issue.
Old 15th November 2017, 06:15 AM   #7
Yes, I have scope and I'll look for oscillation and tried to adjust C11.
Thanks to all for helping me..
Hafler xl-280 pop on startup and higher DC offset oHide this!Advertise here!
DC servo high offset on startup? theAnonymous1 Headphone Systems 13 12th May 2016 05:32 AM
Advice needed on dealing with startup output offset Nighter3D Solid State 25 9th April 2016 09:58 PM
PCM1704 Help needed with higher dc offset from one channel georgehifi Digital Source 12 13th December 2012 10:08 AM
Hafler DH200 DC Offset ronzeman Solid State 28 29th October 2008 06:33 PM
Hafler DH500 DC Offset LHMAudio Solid State 2 27th January 2007 10:00 PM
