Marantz 2216B rebuild
Old 13th January 2018, 09:59 PM   #71
pjf610 is offline pjf610
Hi and Thanks again, Since the relay does not click on and i get 35vcd on that board, doesn't that indicate that there could be something wrong with one of the main amp boards because doesn't the relay protect the main amp??
Old 14th January 2018, 07:43 AM   #72
Mooly's Avatar
If you are seeing 35 volts on the main amplifier output point of that board then that is why the relay doesn't click.
The relay is to protect the speakers as much as anything. 35 volts would destroy them instantly.
Usual cause of a high DC offset would be failed output transistors and drivers. Why they failed would also need investigating. Could be abuse by a previous owner or it might be dries or an intermittent fault on the board.
Old 14th January 2018, 02:11 PM   #73
That is what i was thinking a bad Transistor I will jump into this this week and get back to you
Thanks Pat
Marantz 2216B rebuildHide this!Advertise here!
Marantz 2216B Rebuild Help pjf610 Solid State 4 2nd November 2017 01:56 AM
Marantz CD94 / Marantz CD 65 Gold -- What DAC? poynton Digital Source 5 25th August 2017 01:07 PM
Marantz 510 - Rebuild? LHMAudio Solid State 8 22nd May 2007 02:23 PM
Right speakers for Marantz PM8000 + Marantz CD67-OSE? betto80 Multi-Way 2 24th May 2005 03:21 PM
