Honey Badger vs SKA GB150D vs VHex+
Old 10th November 2017, 11:25 AM   #1
GumGum9000 is offline GumGum9000  Germany
Default Honey Badger vs SKA GB150D vs VHex+
which of this three amps do you think sounds best?
Thanks!
Old 10th November 2017, 12:00 PM   #2
maty tinman is offline maty tinman  Spain
maty tinman's Avatar
Default Icepower 1200AS (class D)
Maybe the newwwwwww class D Icepower 1200AS.
The best of class D all in ones circa 2017. Icepower vs Hypex Ncore?
=> Icepower 1200AS amp kit. Class D like you've never heard before
the shop, but not for the individual customers (like Hypex NC500 vs NC400 modules)
AS Series - ICEpower
Old 10th November 2017, 01:33 PM   #3
PJN is offline PJN  United States
Instead of Hawking someone else's product, I'll try answering your question. I have build both the honey badger and the ska. The ska is a far easier build and sounds very nice. It's on the warm side and a bit soft in the higher frequencies, easy to listen to. The honey has many more parts, it sounds great, good control from top to bottom, sounds cooler, lots of HF detail, runs hot. I still have my ska, had a hiss issue with my honey that I couldn't figures out. Ended up cannibalizing it to build Pass Class A amp, no contest, low power but sounds better than either to my ears.
Old 10th November 2017, 05:24 PM   #4
jwilhelm is offline jwilhelm  Canada
The VHex+ is still my favorite amp in lower power range. I've never heard the SKA GB150D though.
https://www.vzaudio.com/
Old 10th November 2017, 06:51 PM   #5
Vrystaat is offline Vrystaat  South Africa
Build an amp where you have backup to help you in need. The V-hex guy's will ensure that your amp will play!
It is sorry that Pete is not here right now cause the badger seems to be a very good amp, although there will be other to help you. I think that the SKA is a lateral mosfet design. Very good. I have build a similar one that still sounds very good. My bet is the Vhex !
Jan
Old 10th November 2017, 07:05 PM   #6
fab is online now fab  Canada
fab's Avatar
For clarification Ska is not using lateral mosfet but vertical.
I have only built the SKA out of the three amps you mentioned.
Fab
Old 10th November 2017, 09:55 PM   #7
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
PJN, did you build the Pass's Class A amp from his 1970's "Audio Magazine" article or one of his more recent designs?
I finished my SKA years after buying a kit from Greg.
It's a nice amp.
Never built the others.
mlloyd1
Old 10th November 2017, 10:24 PM   #8
I built the alph j , F6, and the M2, the F6 and M2 are my favorites, hard to choose between. The F6 has more grunt though and is excellent, sent the ska packing.
Old 11th November 2017, 12:00 PM   #9
Hi, jwilhem,
I have a few questions.
what's the difference between your VHex+ and NS amp? What kind of PSU do they need?
And are your Protection/Soft Start boards pre-equipped?
Thanks!
Old 11th November 2017, 12:06 PM   #10
And how big would the difference of any of those amps be compared to my currrent ROTEL RB-980BX?
Honey Badger vs SKA GB150D vs VHex+Hide this!Advertise here!
Honey Badger vs ??? merlinx76 Solid State 33 17th January 2017 04:45 AM
Honey Badger troubleshooting BobEllis Solid State 20 17th January 2017 02:31 AM
Help choosing a preamp for a Honey Badger nerdles Analog Line Level 7 5th March 2016 05:15 PM
Choices diyAB (Honey Badger) and GB150D? IansMusical Solid State 0 24th June 2014 01:12 PM
Honey Badger pcb's? famousmockingbird Solid State 4 27th May 2014 11:12 PM
