Nakamichi PA 5 II Resistor
Old 9th November 2017, 12:10 PM   #1
fantacrazy is offline fantacrazy  Italy
Default Nakamichi PA 5 II Resistor
Hi i have a problem with a channel. I found only a R on emettitor burned Only R (i Think autooscillation), manual service tell me replace with a fail safe (1 ohm 2w). I have replace it with a metalized flameproof, make low voltage test, and all ok, so i have assembled and iíll read perfect bias (40mv) for 20 minutes then dropped to 1,5mV and I find all the resistors that measure even 1.8/2.5 ohm (1 ohm) and some interrupted and now There Is only one final transistor burned.
Everything is perfect. In attachment there is PA 7 but is same project
What is the problem? Metallized R is Not ok??
Thank you
File Type: png 5A5BE2F8-4A51-42AA-8C2F-4B7084DD6CDB.png (456.9 KB, 115 views)
Old 10th November 2017, 02:02 PM   #2
Nothing to do. I change R with wirewound and one final transistor. power on and no error, relay close and start, but if i search to set 3,9V on TP3, R of check burn and smoke... i just check every diode transistor R Cap and it’s all right.
Is possible that final transistors also if good to be “burn”?
Can you help me?
Old 15th November 2017, 11:44 PM   #3
djk is offline djk
R.I.P
djk's Avatar
The schematic has part numbers on it, it would be helpful if you would use them.
Candidates for the Darwin Award should not read this author.
Old 16th November 2017, 05:50 AM   #4
Hi i solved, also if problem is manual service because pa 5 II is same pa7 II so i need rebuilding for me schematic in a paper.
the problem was on dual fet input 2sk that over heat change status and oscillated.
there are no more forums than once
Thank you
Nakamichi PA 5 II ResistorHide this!Advertise here!
Resistor placement of L-pad and single resistor presscot Multi-Way 3 7th December 2015 09:31 AM
Nakamichi PA-7II won't power on, limiter resistor blown tenelson Pass Labs 4 13th June 2015 06:56 PM
possible resistor values for a Nakamichi SR-2 receiver Nanook Pass Labs 0 17th January 2010 07:22 PM
Nakamichi faceplate button interface to main unit: resistor ladder? whiterabbit Car Audio 1 3rd March 2009 07:55 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
