Build me a ss direct drive ESL amp, please
Old 27th October 2017, 09:45 PM   #21
Discopete is offline Discopete  Canada
Huh? What do you do with your interfaces?
Old 27th October 2017, 10:48 PM   #22
DaveG is offline DaveG  United States
What I do is listen to a tube amp connected to the MK2 Transformer Interface in 1+1s and it sounds very good.
I also own and listen to the Acoustat Direct Drive amps that I run direct into (no transformer interface) the 1+1s and it sounds even better.
But I am not sure it is all just the OTL that makes the different sound since there is different equalization between the two drive methods.
Dave
Old 27th October 2017, 11:10 PM   #23
PRR is offline PRR  United States
PRR's Avatar
_IF_ you can define the load, the thing practically builds itself. Do not know what you are asking.
I have done exactly this (attached) for an oscilloscope, except at 1/500th the power.
Old 27th October 2017, 11:50 PM   #24
Dave
I see a serious contribution to this thread in your future
Old 28th October 2017, 09:09 AM   #25
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by juma View Post
Wow! big boys indeed; no more need to cascade anything, a straight pair and that's it!
They would be ideally suited to a CircloMOS... Pete, you have your dd amp
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 28th October 2017, 12:41 PM   #26
I love you guys
Old 28th October 2017, 03:19 PM   #27
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
It does indeed look like you can drive 4.5kV with a 10V swing on the gate of these MOSFETs.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 29th October 2017, 04:51 PM   #28
Elvee's Avatar
Here is a CircloMOS adapted for extreme voltages:
Build me a ss direct drive ESL amp, please-uhvcirclo1-png
As the complete transistors models look awkward and somewhat incompatible with LTspice, I have used the internal MOS embedded inside the model.
This means no substrate diode, etc, but it gives a rough idea of what to expect.
The amplifier is capable of delivering 4kVpp, but only up to 10kHz, because the current necessary to charge and discharge the gates capacitance exceeds the driver's quiescent current beyond that.
Build me a ss direct drive ESL amp, please-uhvcirclo2-png
Reaching full power at 20kHz would be possible, but the dissipation in the driver and bias resistors R20 R21 would become really significant.
A workaround would be a floating buffer for M1, but it would require its own, floating supply, which is not simple considering the voltages and frequencies involved.
Anyway, for real musical signals, a full power bandwidth of 10kHz is more than sufficient.
The small signal bandwidth is large enough:
Build me a ss direct drive ESL amp, please-uhvcirclo3-png
Old 29th October 2017, 06:13 PM   #29
padamiecki is offline padamiecki  Poland
http://tubecad.com/2017/10/29/Single...ight%20Way.png
regards, Pawel
Old 29th October 2017, 06:18 PM   #30
userguide is offline userguide  Canada
userguide's Avatar
Default 560 farad !!!
Elvee, in your UHV circloMOS design C4 is really 560 Farad ??
Build me a ss direct drive ESL amp, pleaseHide this!Advertise here!
Direct Drive DSD acko Group Buys 552 10th December 2016 01:18 AM
WTB : Direct Drive Standalone TT Drive Razorblade Swap Meet 0 2nd January 2011 05:22 PM
Direct Drive fun!!! Cobra2 Analogue Source 32 20th January 2007 02:23 AM
Another direct drive thread maudio Planars & Exotics 18 25th June 2006 06:53 PM
