No-global-loop amplification
Old 4th October 2017, 06:55 PM   #21
BesPav is offline BesPav  Russian Federation
Originally Posted by vzaichenko View Post
Following Pavel's post, I have tested the concept with diamond IPS.
Valery, thank you for checking an idea.
Very good results!
The cascodes noticeably reduce 2-nd harmonic, improving overall performance, with 3-rd harmonic dominance. This configuration also shows rather good result in terms of IMD.
Cascoded one needs a cascoded current source for keeping overall concept and idea!
Something like this:
With high enough caps it will also provide nice soft-start with intrinsic noise filtering.
Old 6th October 2017, 05:05 PM   #22
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Arrow Diamondstark PA1
OK, here is my simulation with OPS, utilizing one of the known local error correction techniques. Most of the distortion is coming from OPS anyway, however it looks pretty good even close to clipping (100W @ 8 ohm).
I will simulate a few other OPS options and then - live testing will show if the thing is worth all the work done so far
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 7th October 2017, 09:36 PM   #23
vzaichenko's Avatar
Arrow Simplestark
Finally - not as sophisticated and accurate as the previous one, but a rather simple one and still promising in terms of the way it's going to sound.
Self-biasing IPS, trimmers for OPS offset and bias settings.
http://vzaudio.com/
Old 7th October 2017, 09:40 PM   #24
jwilhelm is offline jwilhelm  Canada
The distortion specs are 1 or 2 decimal places off what you normally design, but I'm curious what these will sound like!
Old 7th October 2017, 09:56 PM   #25
vzaichenko's Avatar
Yes, numbers are not as good, but still decent for no global loop architecture.
I'm trying to find the way to listen to it... still looking for space for the lab
http://vzaudio.com/
Old 7th October 2017, 09:59 PM   #26
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Vz, are you aware of Arto Kolinummi's work on a complete non-global fb amplifier as described in his book?
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 8th October 2017, 09:12 PM   #27
alex mm is offline alex mm  Romania
alex mm's Avatar
Just a little help with PCB . I hope no errors . Maybe someone want to try ....
Old 9th October 2017, 03:01 AM   #28
AKSA is offline AKSA  Australia
Valery,
I really like your amp, and now that Alex MM has done a Tintoretto on your Simplestark, it could become a masterpiece, like the JLH........
Mind you, 12 semis, but very innovative and very good figures for a ZFB amp!
Поздравляем с прибавлением!
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 9th October 2017, 03:53 AM   #29
vzaichenko's Avatar
Jan
Jan, thank you for the link - right to the point.
I have ordered the book.
Valery
http://vzaudio.com/
Old 9th October 2017, 04:05 AM   #30
vzaichenko's Avatar
Hi Alex, thanks a lot for this piece of art - great work, as usual
Would you mind to share the gerbers or whatever interchange format, suitable for ordering the boards (this one will go for no-profit DIY purposes only)?
My building abilities are temporary limited, but I will find the way to prototype and test this one
Valery
http://vzaudio.com/
No-global-loop amplificationHide this!Advertise here!
Closed-Loop Amplification with Driver Cone Position Fedback xrk971 Planars & Exotics 44 23rd July 2013 01:51 AM
No global feedback preamplifier smithomo Solid State 6 18th December 2011 02:31 PM
possible advantage to global??? mashaffer Tubes / Valves 20 28th December 2010 05:43 PM
GAS - Global Amplification Stage Stee Solid State 17 19th August 2008 03:58 AM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
