No-global-loop amplification
Old 30th September 2017, 11:17 AM   #11
jwilhelm is offline jwilhelm  Canada
We've been working on a preamp design that incorporates NGFB for the input buffer, and will likely use a NGFB headphone amp too (still to be designed and built).
Old 30th September 2017, 11:22 AM   #12
BesPav is offline BesPav  Russian Federation
Default No-global-loop amplification
Originally Posted by vzaichenko View Post
Exactly, dual-diamond configuration with the diamonds, loaded to each other. Rather simple and efficient.
Valery, are you ever tried even simpler four-quadrant self-biased cascoded IPS like this?
Or matched arrays like THAT340/ALD1103? Last one have dedicated substrate connection.
THAT1206 seem to have 7 kOhm at input in-series and could degrade noise performance in low-level applications.
Old 30th September 2017, 12:56 PM   #13
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Originally Posted by dadod View Post
Valery, as always you have very good ideas how to design different amplifiers. You use diamond OPS here, how you do thermal compensation here, I never built any diamond power OPS yet (only for preamp)? How you get THD 0.002% if OPS alone has 0.05%?
I designed no GNFB but never built yet, to many project, have you built that one, if yes, how you like the sound?
This is my NGNFB amp and it uses current mirror with current gain of 2.12 GainWire-NGNFB-classB-PowerAmp
Those are my preamps with no GNFB, also uses current mirror. Current conveyor as a voltage amplifier and No NFB line amp (GainWire mk2)
Maybe you can get some ideas from it, like to use supper pairs.
P.S. pity you don't use LTspice
Hi Damir,
Good to see you here
Part of the circuit, shown on the schematic, does not include OPS - diamond on the right is the unity gain buffer. Connecting the OPS right to the transimpedance stage results in significantly higher level of distortion because of OPS's input impedance modulation. Buffer does the job perfectly.
So, distortion figures shown on the pictures are true for the front-end only.
NS-OPS dictates overall level of distortion at around 0.05%, running open loop.
Valery
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 30th September 2017, 01:02 PM   #14
thimios is offline thimios  Greece
Yours test man is here
Old 30th September 2017, 01:05 PM   #15
Still waiting for a shopping list for the other inputs.
Old 30th September 2017, 01:50 PM   #16
vzaichenko's Avatar
Yep, this one incorporates a simpler unity gain buffer, particularly designed to match NS-OPS though
http://vzaudio.com/
Old 30th September 2017, 01:55 PM   #17
I will do soon
These days NS is on my test bed again.
Old 30th September 2017, 03:35 PM   #18
vzaichenko's Avatar
Attachment 637998
Hi Pavel,
Yes, I have used this kind of self-biased IPS arrangement, based on 2sk246/j103 pairs in one of X4 front-end options.
Noise - at low levels yes, but at line levels - no problem
http://vzaudio.com/
Old 1st October 2017, 05:11 AM   #19
vzaichenko's Avatar
http://vzaudio.com/
Old 4th October 2017, 06:18 PM   #20
vzaichenko's Avatar
Arrow Diamondstark
Following Pavel's post, I have tested the concept with diamond IPS.
Initial setup did not include common base cascodes U8, U9 - overall distortion level was roughly 1/2 from what we've seen with differential pairs in place, still copying that initial profile.
The cascodes noticeably reduce 2-nd harmonic, improving overall performance, with 3-rd harmonic dominance. This configuration also shows rather good result in terms of IMD.
It's also cool to be able to use +/-15V regulated rails for IPS, allowing low-voltage complementary transistors.
Live performance is going to be slightly lower, strongly depending on components selection, as a number of important parts are either out of any NFB loop, or form the local loop itself.
http://vzaudio.com/
No-global-loop amplificationHide this!Advertise here!
Closed-Loop Amplification with Driver Cone Position Fedback xrk971 Planars & Exotics 44 23rd July 2013 01:51 AM
No global feedback preamplifier smithomo Solid State 6 18th December 2011 02:31 PM
possible advantage to global??? mashaffer Tubes / Valves 20 28th December 2010 05:43 PM
GAS - Global Amplification Stage Stee Solid State 17 19th August 2008 03:58 AM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
