No-global-loop amplification
Old 9th February 2018, 04:22 AM   #171
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
It has been a while without updates. Anything new?
Ciao!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 9th February 2018, 10:50 AM   #172
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
I continue listening to my single channel prototype - running nicely, slowly building the 2-nd channel, thinking about the point raised by Brian about the best balance between the gains of the front-ends.
My approach right now - if I want an overall gain of the power amplifier to be 29db, I set the gain of the "main" (high swing) OPS to 29db. The opamps (or some other error correction circuit) adds 18db on top, that is "balanced" by 18db NFB loop. I believe, around 20db is a reasonable value, assuming the "main" front-end is linear enough.
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 15th February 2018, 04:53 PM   #173
vzaichenko's Avatar
Default Better spectrum measurements
I've set up my recently received RTX audio analyzer in the lab - now I can show better measurements.
The first picture - note the noise floor with no signal - no noise / hum components above -120db line. Then THD for 1KHz and 20KHz, and IMD 14+15KHz go.
Listening to the amp - also through the analyzer's DAC - I would characterize the sound as "smooth and delicate" - no highlighting of anything, very comfortable listening in the near field (speakers are placed on the corners of a big table).
One 10pF bandwidth-limiting capacitor is added to prevent possible "ringing" when touching the input with something not grounded.
The design is rather mature now - easy to reproduce.
I'm thinking about a servo option for those who like rock solid zero offset, although right now possible fluctuations don't exceed +/-10mV.
http://vzaudio.com/
Old 19th February 2018, 05:26 PM   #174
vzaichenko's Avatar
A fully tuned-up, mature version of Simpelstark.
I will update the post#1 with amended schematic and corrected layout (one additional capacitor is underneath the board now).
http://vzaudio.com/
Old 20th February 2018, 08:47 AM   #175
traderbam is offline traderbam  Europe
traderbam's Avatar
Looks good. What capacitor did you add? Did you settle on 20dB global NFB?
Everything matters.
Old 20th February 2018, 09:19 AM   #176
vzaichenko's Avatar
Arrow V1.1
The one I have added is C20 (10pF). It closes the loop around the front-end at HF, preventing possible local oscillation when the input is touched with no ground reference.
The 2-nd picture shows the real board view from the top (ground plane), the 3-rd picture - the ground plane is shown transparent to see the routing.
I have stayed with 18db loop gain in ODNF mode. If somebody wants to use the circuit in a pure no-global-loop mode - he can drop all the components within the red box, shorting TP2 and TP3 with a wire.
P.S. Added the bottom view of the board with the proper copper pours.
P.P.S. What still amazes me in this amplifier - the noise / hum level. This is the quietest amplifier I've ever designed - dead silent at idle. To be honest, I didn't expect it to be that quiet when I just started thinking about this design.
http://vzaudio.com/
Old 20th February 2018, 09:56 AM   #177
vzaichenko's Avatar
Post #1 is updated with the links to this page.
http://vzaudio.com/
Old 20th February 2018, 07:43 PM   #178
pinnocchio's Avatar
Will you have some PCBs available?
Do
Old 20th February 2018, 07:48 PM   #179
jwilhelm is offline jwilhelm  Canada
I have a couple of the original boards in stock. Valery sent me corrected files but was hinting that a new more compact layout is coming so I'm going to wait for that before having more boards done.
https://www.vzaudio.com/
Old 20th February 2018, 07:52 PM   #180
pinnocchio's Avatar
I'll wait for the new board
Do
No-global-loop amplificationHide this!Advertise here!
Closed-Loop Amplification with Driver Cone Position Fedback xrk971 Planars & Exotics 44 23rd July 2013 01:51 AM
No global feedback preamplifier smithomo Solid State 6 18th December 2011 02:31 PM
possible advantage to global??? mashaffer Tubes / Valves 20 28th December 2010 05:43 PM
GAS - Global Amplification Stage Stee Solid State 17 19th August 2008 03:58 AM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
