Marantz pm-7200 ground loop / buzzing sound
Old 12th September 2017, 04:52 PM   #1
dj_holmes is offline dj_holmes  United Kingdom
Default Marantz pm-7200 ground loop / buzzing sound
Hello,
was wondering if anyone could help. Trying to fix this amp for a friend and its producing humming / buzzing sound regardless of volume. It has jumper cables at back and I know for a fact the preamp is working fine so its the power amp not working. I have also tried replacing a few caps in the protection circuitary that may casue this but still getting a loud buzzing sound from it. I also tried measuring dc offset and there was none. I'm stuck! Any suggestions please?
Old 13th September 2017, 05:20 AM   #2
CaseSensitive is offline CaseSensitive  Australia
humming when nothing else is connected?
Old 13th September 2017, 02:05 PM   #3
Yes, turns out the large caps has a solder joint that was blown off!! Soldered it resolved problem
Marantz pm-7200 ground loop / buzzing soundHide this!Advertise here!
Ground isolation loop problem ? Motorboat ticking sound rajkumar88 Chip Amps 13 26th April 2017 08:46 PM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
Digital Woes (Elite DV-45A ground loop and bad sound) pjpoes Digital Source 0 7th March 2005 07:32 PM
Buzzing, could it be a ground loop? JoeBob Tubes / Valves 3 14th July 2003 02:24 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright ©1999-2017 diyAudio
